What Does the Area in Faraday's Law Represent?
  • Thread starter Thread starter darksyesider
    Faraday's law Law
In Faraday's Law, the area in the formula for magnetic flux (φ) represents the region enclosed by the loop where the induced electromotive force (emf) is being measured. When calculating φ for a loop around a toroid, it is essential to consider the area that is actually within the magnetic field. The correct approach is to use the area bounded by the loop itself, which may differ from the total area of the region if the magnetic field is not uniform. Therefore, for a toroidal loop, φ should be calculated based on the area that intersects with the magnetic field. Understanding this distinction is crucial for accurate emf calculations.
darksyesider
In the formula: ## emf = -\dfrac{d\phi}{dt}##, ##\phi = \int B\cdot dA##.
Does the area mean only the part of the region which has a magnetic field (if it's constant)?
for example, if you have a loop around a toroid, and want to calculate the induced emf, would ##\phi = B(\pi radiusoftoroid)^2 ## or ##\phi = B (\pi radiusofregion)^2## ?
I personally believe the former, but cannot verify this.
The area is the area bounded by the loop along which the emf is being measured
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
