Faraday's law on circular wire
66 replies · 8K views
I'm confused? Dude who are you? How far did you get in EE, BS, MS, Ph.D.? Honestly I don't believe what you're saying. If the emf open circuit is 1.0 V, are you claiming that to compute current we ignore L & C and just divide by R? Every text in the world uses the RLC diff eq for the solution. That is my "reference". Are you full EE student/grad, or are you EET? What texts are you relying on?
It should not matter who I am. This is an elementary A-level question so nothing more than A-level is needed to get the answer.
If you cannot agree that, using the values quoted above, emf = 1 volt and current = 1Amp then you are in serious disagreement with A-level teaching and A-level textbooks.
Whatever you do...do not criticize teachers or the textbooks they use! If the answer is correct at A-level...it is correct.
If you do not agree with the calculation then I urge you to give an answer to this question. There are countless examples in a whole range of physics textbooks.
Do you accept that explanations and answers to questions should conform to textbooks used in teaching?
The question I posed, and I believe the original post refers to, is a standard A-level type question with a very straightforward answer given in all A level textbooks.
The equation v = -N*d∅/dt is a broad statement. What is "∅"? It is not only the external flus linking the loop, but the loop's own internal flux as well. Look up "inductance" and see for yourself.
As long as the loop has L, which it must have, a portion of the total flux inside the loop area will be due to its own self inductance L. This affects "v". Otherwise conservation of energy is violated. If I = Voc/R, with no regard to L & C, you're saying that a copper loop with heavy wire, 0.001 ohm R value, with Voc - 1.0V, will result in 1000 amp??!? I don't think so. If a superconductor is used, what is the current technician?
Your references do not go into the depth of detail needed for these questions. Any EE w/ a motor theory background knows what I'm saying.
Claude
Claude
You are wrong.
I have no more to add...going round in circles
technician said:
You are wrong.
If I am wrong, please inform us where I went wrong. I know it's been 7 weeks, but it takes more than just telling someone they are wrong to prove them wrong. Please examine the following and state where you disagree.
A wire loop immersed in a time-varying magnetic flux, ∅, will incur induction. The loop has a resistance R, and an inductance L, and if open, the gap will determine a capacitance C. Each quantity, R, L, and C, will contribute to the loop total impedance value Z.
Z = R + jXL + 1/jXC.
When open circuited, the voltage is measured and denoted as "Voc". When short circuited, current is measured and denoted as "Isc". Unless the gap is very small, the area of the wires is generally too small to result in substantial capacitance. At low and medium frequencies, "XC" can usually be neglected.
So to simplify things, we can approximate loop impedance Z as the following:
Z = R + jXL. Of course, XL = ωL. So then:
Z = R + jωL, which is expressed in rectangular (Cartesian) form. To express Z in polar form:
|Z| = √R2 + (Lω)2, angle Z = arctan (Lω/R).
When loop is open, Z is infinite due to gap in wire so that V = Voc, I = 0. When a loading resistance Rload, is placed across the gap in the loop, what is the measured V & I at the load?
There is a voltage divider here. If Rload >> Rwire, we still have to deal with XL = Lω.
Ignoring Rwire, Vload is as follows:
|Vload| = |Voc|*Rload/√((Rload)2 + (Lω)2)
The above gives the magnitude of voltage at load in terms of open circuit voltage, R, ω, and L. Since Lω is XL, if Rload >> XL, then the radical in the denominator is approximately equal to Rload. So we have Vload = Voc*Rload/Rload, or Voc = Vload.
For Rload >> Lω, we can assume that Vload will remain nearly equal to Voc for any Rload value >> Lω. Also, Iload = Voc/Rload, as long as Rload >> Lω.
Any motor/generator text will affirm this. Induction motors with squirrel cage rotors discuss this analysis. Look up "deep bar rotors" or "double squirrel cage rotors". These utilize the relation between R and Lω to optimize starting torque and run torque. At standstill, ω = ωline (ac line frequency i.e. 2∏*50/60 Hz), so XL = maximum, so the impedance is computed taking both R and XL into account.
When running ω is a small fraction of ωline, the "slip" frequency, typically 2% to 5% of line frequency. So here XL is very low, much less than R. Hence R dominates the impedance of the rotor.
The following texts affirm what I've posted:
Electromagnetic and electromechanical machinery, Leander Matsch
Electric Machinery, Fitzgerald, Kingsley, Umans.
I will elaborate if desired. Best regards to all.
Claude
Claude
Did you read my post26 ?
Do you agree with this basic calculation seen in many standard textbooks?
Yes I read #26. What standard textbooks are you referring to? In your example, you simply assume that the loop impedance is defined entirely by R, w/o regard to what L or ω are. This cannot withstand scrutiny. As I've already stated repeatedly, your method will work but only with the condition that R is higher in value than XL by a factor of 5 or more. Let's look at your example.
If dB/dt is 1.0 tesla/sec, Aloop = 1.0 sq meter, and R = 1.0 Ω, how do we compute I and V? Let's assume square wire, because it is easier to compute, but round wire could be used w/ an adjustment factor, but for now square will do. Also we use a circular loop. Let the wire thickness be 1.0 mm. Since area = 1.0 meter2, computing L is easy.
L = μ0N2Aloop/h, where "h" is the height of the loop, or 1.0 mm here (wire thickness), and "N" is one, the number of turns.
L = (4∏10-7henry/meter)(1 turn)2(1.0 m2)/(10-3 m),
L = 1.2566 millihenry. So that at a frequency of 1.0 radian/second, XL = 0.0012566 ohm. Because this value is much less than 1.0 ohm R value, for all practical purposes, ignoring XL and using R only is close enough. Hence I is very close to 1.00 amp.
But if ω = 1,000 rad/sec, and flux amplitude is correspondingly reduced by a factor of 1,000, the XL value is now 1.2566 ohm, which is greater than the R value of 1.00 ohm. Thus the total loop impedance magnitude |Z| is √(1.00)2 + (1.2566)2. |Z| = 1.6060 ohm. Hence |I| = 1.00/1.6060 = 0.6227 amp.
The load voltage is |V| = 0.6227 volt. As you can see, there's more to it than just assuming that the entire loop impedance consists only of R. When R attains a low value, the inductance of the loop comes into play. The example you gave just happens to work out w/o considering XL because the radian frequency ω is extremely small, 1.0 radian/second.
But in cases of induction, that is a very low frequency, around 0.159 Hz. As I showed, if ω is 1,000 rad/sec, only 159 Hz, then XL cannot be ignored. In fact at 300 rad/sec (47.75 Hz), we must consider XL. Power line frequencies of 50/60 Hz are high enough so that you cannot ignore loop inductance.
I hope this example serves to illustrate that there is usually more than 1 thing going on in a problem like this. Faraday's law simply conveys a math relation between NET flux and emf. But the "∅" in the equation is not merely the external flux cutting the loop, it is the composite of external plus internal flux due to loop current and its own self inductance.
The problem with your approach is that if the loop is very low R value, say 0.001 ohm, the answer you get for I is 1,000 amp! Clearly this is not the case. With 0.001 ohm R value, and 0.0012566 XL value, the I value magnitude is 622.7 amp. So the 1,000 amp value is high by 61%.
Something to ponder. I will elaborate if desired. Best regards to all.
Claude
I am a teacher...the number of textbooks that I could refer to is countless! The ones I use that you may find helpful are Nelkon & Parker, Duncan, Breithaupt, Young & Friedman and AQA exam textbooks.
Any answer/explanation I have provided is to be found in any of these. I also use the Hyperphysics web site. I am ONLY interested in the original post... a permant magnet and a circular coil. I think that has been covered.
I am not interested in sqirrel cage motors (this post has more to do with generators than motors)
I do not see where your dB/dt = 1 tesla/sec and a 'frequency' (?) of 1 rad/sec and then an ω = 1000rad/sec come into the explanation.
Sorry... I stick with my textbooks. If you want more discussion on this topic I suggest you start a fresh post (I will probably not contribute) because this is now nothing to do with the original post, in my opinion.
Circuit theory is a well researched science, with little new in the last century. Impedance being the phasor sum of resistance and reactance cannot be disputed. You have not addressed my R + jX explanation. I will research the books you mentioned, but frankly, I am wondering if they actually say what you claim they say. I will find out and comment. BR.
Claude
I would ask technician to seek a credible authority on e/m field theory and ask them to affirm or refute my statements as follows.
A loop with a gap having negligible capacitance is placed in a time varying mag field. The open circuit voltage Voc is measured. The gap is then connected across a resistance R. What is the current? Claude says that I is the ratio of Voc to Zloop. And that Zloop = √R2 +XL2.
Why is this wrong? Technician, your answer is that as R decreases, I and power P increase unbounded. This flies in the face of energy conservation. Decreasing R does result in increased I only until R is much less than XL. The maximum loop current, I, is Voc/XL. Decreasing R to 0 results in this maximum current value.
The power in R is I2R, or Voc2/R. The mag field has limited power, so dissipation in R is limited. My result affirms this well known fact.
Later I will construct a paper detailing this. BR.
Claude
here is a worked example from Young and Freedman (it is a very common example!)
If anything is wrong with this example then there is something seriously wrong with standard textbooks !
I, personally, am not going to reproduce standard textbooks here...they are available for all to refer to.
This answers the original post.
I think you should consider that technician might be talking about the steady-state solution for the induced current when the rate of change of flux through the loop is constant in time. The current is then indeed 1 A for a rate of change of flux of 1 Wb/s through a closed loop with a resistance of 1 ohm, regardless of its reactance.
It does not. As the induced current increases, so does the magnitude of the induced magnetic field. This in turn increases the force you'd have to apply to the magnet to produce whatever displacement profile that's needed to induce the constant rate of change of flux through the loop. Decreasing the resistance of the loop increases the mechanical power supplied, as it must, to make up for the increase in Joule heating in the conductor.
The author assumed that XL << R, so that would be correct only under that specific condition. The motor/generator texts specifically include XL in the equivalent circuit and use this for calculations. I will post an illustration tonight, but I will start a new thread so we can elaborate w/o bothering this thread.
By the way, the Nelson & Parker is the book I looked at. Some of the contributions were made by college instructors, some were high school, and one contributor was a grammar school instructor. BR.
Claude
cabraham said:
The author assumed that XL << R, so that would be correct only under that specific condition. The motor/generator texts specifically include XL in the equivalent circuit and use this for calculations. I will post an illustration tonight, but I will start a new thread so we can elaborate w/o bothering this thread. BR.
Claude
I look forward to your new thread. I am happy that this one is finished.
'THE AUTHOR' = all authors
Ps the induced emf is sometimes called a 'back emf' and the induced current ( if there is one) is sometimes called an eddy current.
It is worth reading about these, their relative directions (Lenz's law) and energy conservation
That is where we disagree. Reactance matters. Regarding increasing the force, you have now changed the op problem. Two identical loops are examined, one has 10 ohms, one has 1.0 ohm. If both are open circuited, the induced voltage, Voc, is the same for both.
If both are loaded w/ 10/1.0 ohm load resistances, depending on reactance, the currents are not always simply Voc/Rload. Regarding your statement about increasing force, that would also increase Voc. In order to make up for increased induced mag field you are increasing force. But that in itself increases the open circuit emf Voc. The problem has changed.
I will begin a new thread tonight, and we can take this further. I will conclude with this. To increase the force will inevitably result in a new value of Voc, hence the problem is not as simple as I = Voc/Rload. That is my point. With original force value, we get emf (open circuit) = Voc1. If R << XL, so that reactance cannot be ignored, and we increase force to assure that we restore original net flux value, we now must compute current using a new value of Voc, namely Voc2.
With this increased force, if load is suddenly removed, Voc2 > Voc1. That is inevitable. Thanks.
Claude
Let's just first agree that we're considering an example where you have a conducting loop, fixed in space, within a time-varying magnetic field, such that the rate of change of flux through the loop is constant in time. Assume a rate of change of flux of 1 Wb/s.
That's fine. The induced emf would be 1 V.
In the case of a closed loop with a resistance of 1 ohm, the steady-state current will be 1 A.
In the case of a closed loop with a resistance of 10 ohm, the steady-state current will be 0.1 A.
You could just as well consider the step reponse of a RL-circuit to a constant voltage. Its steady-state current is certainly not a function of the reactance of the circuit.
It would not. You're displacing the magnet such that the rate of change of flux through the loop is 1 Wb/s. That determines the open-circuit voltage. The motion of the magnet, regardless of the resistance of the loop, is the same. What changes is the mechanical power you must supply to produce this motion. It's an effect of reducing the resistance of the loop.
I really can't make sense of any of this. The reactance has nothing to do with the steady-state current in the circuit.
It is a great book, the bible of A-level physics...did you find that it is more or less the same as Young and Freedman in its explanation?
I prefer Duncan. Have a look at that one.
PS... I am a grammar school 'instructor'
Well of course the "steady state" current is zero regardless of R as well as L. If we're talking a magnet passing through a coil, then "steady state" is zerp period. The transient is all that happens. I will start a new thread based on a continuous time varying field, such as a generator, xfmr, antenna, etc.
FWIW, I don't think there is any dispute that Voc is determined by the change rate of flux of 1.0 web/sec. Here is my beef. A rate of "1.0 weber/second", can be d∅ = 0.1 web, dt = 0.1 sec; or d∅ = 0.01 web, dt = 0.01 sec; or d∅ = 0.001 web, dt = 0.0001 sec, etc., so that the rate is always 1.0 web/sec.
Here is my difference in thinking. If d∅ and dt are very large, the effective time constant is very large, and the L value has less influence. But if d∅ and dt are both very small, like 1.0 microweber per microsecond, then the time constant is very short, thus L has a significant influence.
If the L/R time constant of the loop is 1.0 millisecond, do you agree that the results are different for a 1.0 second time constant for the magnet crossing the loop as opposed to a 1.0 microsecond time constant. If the L/R time constant is smaller than the magnet motion time constant, you and I likely agree that L has little influence, and only R need be considered. We likely agree there.
Where we likely DISagree is the following. If the magnet moving through the coil takes place in 0.1 seconds, but the L/R time constant is 1.0 seconds, 10 times longer, we cannot ignore the influence of L. Do you follow? Thanks.
Claude
The premise was that the rate of change of flux through the loop was constant in time. I asked you to consider what the steady-state solution for the current would be in that case, since the solution would be consistent with the one given by technician in post #26. It's also a common example in introductory physics texts, so it seemed probable that you weren't arguing from the same premise.
For a magnet passing through a coil, the rate of change of flux through the coil isn't constant in time.
cabraham said:
If the L/R time constant of the loop is 1.0 millisecond, do you agree that the results are different for a 1.0 second time constant for the magnet crossing the loop as opposed to a 1.0 microsecond time constant?
The premise for my example, and the one given in #26, is that the coil is within a time-varying magnetic field, such that the rate of change of flux through the coil is constant in time. You'd have to consider, for instance, a bar magnet approaching (not passing through) the coil in such a way that it produces a rate of change of flux through the coil that is constant for a period of time long enough for any transient to decay away. Only then are we discussing equivalent systems.
But we can simplify as follows. Let's say the magnet passes through the coil such that we get a trapezoidal open circuit voltage Voc = 1.00 volt at the plateau, with a duration of 0.10 seconds. What is I the loop current? You mentioned "steady state", but can we assume that the system reaches steady state?
If the L/R time constant of the circuit is 0.010 seconds, then we can discuss the steady state current as settling to Voc/Rload. If Rload is 10 ohm, steady state current is 0.10 amp. Likewise, for any larger pulse wave duration, 1.0 sec, 10 sec, etc., the L/R time constant determines the transient response, but the steady state is Voc/Rload.
But if the open circuit voltage wave duration is 0.10 sec as above, but L/R time constant is 1.0 sec, then the system never reaches steady state. Any good text, Millman/Taub/Schilling "Pulse Digital & Switching Circuits" & "Digital Integrated Electronics" will show the detailed math. With 0.10 sec Voc at 1.0 volt, L/R, I will ramp up at a rate (Voc/L)*t. When the current is about 1/10th its "steady state value", the Voc is gone and current decays never having attained its steady state value.
With ac continuous excitation, the criteria is that R >> XL, so that Iload = Voc/R. With a single pulse, the criteria for Iload = Voc/R, is as follows:
duration of Voc pulse >> L/R time constant.
Best regards.
Claude
That's not simplifying, it's an entirely different scenario.
Again, the premise for my example, and the one given in #26, is that the coil is within a time-varying magnetic field, such that the rate of change of flux through the coil is constant in time. Regardless of how you go about producing such a field, that's what you have to consider. In that case, the steady-state current is the ratio of the open-circuit voltage to the resistance of the conducting loop.
I'm well aware of what influence the time constant has in your example, but if you want to discuss a scenario where the rate of change of flux through the coil isn't constant in time, then:
Claude
This is a highly respected textbook ( all of my textbooks are!) ...are you seriously questioning these books with an assertion that the authors are making some unqualified 'assumption' ?
Do you believe the answer is only correct within certain assumptions ?
I believe that you are confusing AC circuit analysis with physics explanations!
Yes, I'm suggesting that this text makes assumptions, which in some cases are not unreasonable. It's like Galilean relativity in HS physics. If 2 cars approach each other w/ speeds v1 and v2, the relative speed is v1+v2. But in uni physics, if 2 space ships at speeds within an order of magnitude of light speed, Galilean approach is no good, and relativity applies.
My position is that sometimes L is too small to matter. Your approach works in that case. But in cases where L is large enough, a different result is obtained, your approach needs modified.
No no no no no... I wondered when the speed of light was going to come into it !
None of this is 'MY' approach that needs modifying.
It is standard physics textbook references. The complications caused by the speed of light are dealt with appropriately in these books at the appropriate time.
I still believe that you are confusing circuit analysis where changing currents cause changing magnetic fields with the physics of changing magnetic fields causing induced emfs.
Your introduction of ω into your explanation confirms this for me.
Have you considered the problem from a conservation of energy approach?
Some tips... E = -d∅/dt ...I = E/R ... E = Blv ...F = BIl...power = i2R
Cons of energy supports me. E =-dphi/dt must consider flux from external source as well as internal loop flux due to self inductance.
If E is constant regardless of R, then P = I^2*R which equals E^2/R. If E stays fixed, R decreasing results in unlimited increase in power. Decreasing R will increase power until R equals X, where max power occurs. Decreasing R belowthe value of X will decrease power. Current I, is determined by Voc/Z, where Z=R+jX. Otherwise energy conservationis violated. I'll draw a pic later. BR.
Claude
Say I apply a constant voltage across a resistor with resistance R. Are you saying that, since I'm able to increase the power delivered to the resistor by decreasing R, I'm somehow violating the law of conservation of energy?
If the voltage is induced via magnetic field, then there is a limited amount of power in the field. Reducing R will demand more of that power. When R = X, power in R is half that of mag field. Decreasing R results in less heating power in R. More later.
Claude
cabraham said:
If the voltage is induced via magnetic field, then there is a limited amount of power in the field. When R = X, power in R is half that of mag field. Decreasing R results in less heating power in R.
Let me try another example:
I'm moving a bar magnet towards a closed conducting loop such that the the rate of change of flux through it is constant in time. I'm able to maintain this for a very long time, far longer than, say, 4-5 time constants of the equivalent RL circuit for the loop, so I have a very long period of time where the current in the loop is constant in magnitude. Let's call this the steady-state current.
Note that time-varying does not mean, for instance, that the magnitude of the magnetic field has to vary sinusoidally. In my example, the magnitude of the magnetic field could be increasing monotonically at a constant rate with respect to time.
Assume a rate of change of flux through the loop of 1 Wb/s, so the open-circuit voltage is 1 V. Say the resistance of the loop is 1e-3 ohm, so the power delivered to the conductor is 1000 W.
There's potential energy stored in the magnetic field produced by the steady-state current in the loop, but this has nothing to do with the power delivered to the conductor through the interaction of the induced magnetic field around the conductor and that of the bar magnet. It takes significant work, 1000 W worth to be precise, to maintain the motion of the bar magnet that produces the constant rate of change of flux through the loop. If the resistance of the loop was 1e-6 ohm, you'd have to supply 1e6 W mechanical power to be able to maintain the motion of the bar magnet that produces the constant rate of change of flux through the loop, and so on. There's nothing about this that violates the law of conservation of energy.
Now, please don't start with the time constants again. I know what you mean, but it has nothing to do with my example. I also know what complex, real and reactive power means, but again there's no reactive power involved in my example.
Now you're talking motor theory. With motors or generators, to increase power requires more fuel to be spent. CEL (conservation of energy law) is ok as long as the mechanical power to generator shaft equals output electrical power plus losses. But mu point is that the added energy comes from somewhere. But remember that the open circuit voltage does change. If you load the loop with 0.001 ohm, and you increase the force on the magnet, you have really changed Voc. The value of Voc increases with increased force to magnet. If the load R is 10 ohm, I=0.10 amp, Voc = 1.0 volt, let's call these Iload1, Voc1, and R1. Let R2 = 0.001 ohm, but force on magnet and work increase by 10^4 to make up for loading effect.
The new Voc2 cannot now still be 1.0V, w/ Iload = 1000A. If the load resistor has 1,000A at 0.001 ohnm R value, the voltage at the load resistor is indeed 1.0V. But if we suddenly open the load from the loop, Voc2, the open circuit voltage w/o load, but with increased force on magnet, is much greater than 1.0V, more like 1e4 volts.
In generator design we call this condition a "load dump".
Claude
