Fast Fourier Transform (FFT) Input Question
The discussion clarifies the concept of "N-point" in Fast Fourier Transform (FFT), indicating that it refers to the number of sampled points used for computation, which directly affects the resolution of the frequency spectrum. Each "point" is a data element in a vector, typically representing complex numbers, often starting with the imaginary part set to zero. The FFT is a fast implementation of the Discrete Fourier Transform (DFT), which analyzes the frequency content of digital signals sampled from analog sources. For instance, a 1-second audio clip sampled at 8kHz results in an 8000-point vector, and performing an FFT on it yields a frequency vector of the same size. Understanding these fundamentals is crucial for effectively interacting with FFT in signal processing applications.
HD555
Hi, I have a question about the FFT. I'm starting to learn the concepts behind it, but I'm struggling at this one particular thing...
Ok, let's say you have this diagram. http://www.ece.uvic.ca/499/2004a/group05/image/radix2.jpg
Can someone explain to me exactly what "N-point" means? Also, what a "point" is?
And... what exactly does into these inputs... like x(0) and x(1) and ... x(15)? Are they complex numbers? 1s and 0s? Maybe 1 sample size per x(#) of 16 bits?
As you can see, I'm pretty much confused on how this actually works and how to interact with it. Thanks!
a point is a datum, an element in a vector. that is a 16-point vector of data. the values in each element are complex, but you usually start with the imaginary part set to zero. if you start with reals, the result will be complex, and symmetric about zero as complex conjugates.
Hi HD555, the FFT is actually a fast implementation of the Discrete Fourier Transform (DFT). The DFT is *simplistically*, a sampled version of the spectrum of a signal.
In computers, we work with digital signals which are samples of some analog (continuous) signal. Let's say for example speech. If I record a 1 second clip of somebody talking, I am actually storing a vector of numbers. The length of this vector depends on my sampling period or frequency. If I sample at 8kHz (or 8000 samples per second), then my 1 second clip will be stored as a vector that has 8000 elements.
Ok, now if I want to inspect the frequency content of this signal, I look at its Fourier transform using the FFT. The FFT will give you a sampled version of the signal spectrum. The "points" that you mentioned play a role in the resolution of the frequency spectrum that you will see. For example, in the "normal" mode, simply taking an FFT of a signal will return to you a frequency vector of the same size. In our case, a frequency vector of 8000 samples. This means that the entire frequency range between 0 to 2pi is divided into 8000 sample points. If you take a 10000 point FFT that means that you will be returned a frequency vector which is 10000 points long. It represents the same spectrum but this time the frequency content between 0 and 2pi is divided into 10000 points.
Hope that helps.
"N" in the N-point FFT represents the number of sampled points taken for computation.
For example consider a sinewave containing 64 samples.
When u apply these 64 sample points to an FFT engine it is called 64-point DFT.
Since the sample points are obtained by sampling the time domain signal .. they are real values.
In matlab,
take x = input signal on which DFT has to be calculated.
y = fft(x,n) is the n-point FFT. If the length of x is less than n, fft pads x with trailing zeros to length n. If the length of x is greater than n, fft truncates the sequence x
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
