Making a Uniform Mixture of Helium Gas
ibysaiyan
Question
This is an experiment on a dilute isotopic mixture of helium gas. A spherical vessel of
diameter 1 m is first filled with 4He gas to one atmosphere pressure. Then a small
amount of 3He gas is introduced through a valve on one side of the vessel. Make a
rough estimate of how long one must wait before a uniform mixture has formed (use
the result for the time dependence of the root mean square travel distance in a
random walk in 1D.) Suggest a better way to make a uniform mixture.
Area = pi (diameter/2)^2 , pv =nrt , ficks law of diffusion , Mass flux = 1/3lv
I am not sure where to start from. I am reading about fick's law of diffusion right now however I'd love tobe pointed out in the right direction.
Since the question asks for time dependence then isn't second law the most obvious equation to use ?
edit: hm.. as i was reading i came across this idea.. how about i get the area first, then divide volume by area to give me the 'length' which i can plug into ficks equation if I am not mistaken.
Appreciate your help.
Anyone?
Never mind.. can one of the moderators please close this thread. I have figured out the final answer,etc.. took me countless sheets but it was worth it.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
