Commutative Ring with Unique Ideals: Solution Using \mathbb{Z}_4
noospace
I'm trying to find a commutative ring, not a field, who's only ideals are {0} and itself.
Definition: A subset of a ring R is an ideal if it is a subring of R and is closed under multiplication by elements of R.
I claim \mathbb{Z}_4 has the desired properties.
\mathbb{Z}_4 is a commutative ring.
\mathbb{Z}_4 is not a field since it has zero divisors.
The only proper nontrivial subring of \mathbb{Z}_4 is {0,2} and {0,2} is not an ideal (not closed under multiplication by 2).
Was this actually the question? Or was it something more of the form "does there exist a commutative ring whose only ideals are {0} and itself that is not a field?"
This definition isn't quite right. An ideal, I, is a subring such that rI and Ir are subsets of I for every r in R. (for a two-sided ideal).
But if you multiply the elements in {0,2} by 2 you get {0} which is contained in {0,2}.
If the condition were that rI=I for every r in the ring than there would only be one ideal {0}, because 0 must be in the ideal since it is an additive group and multiplying by 0 will only give zero then 0*I would be {0}.
You're correct and in fact Z_4 does not satisfy the required properties since {0,2} is not an ideal.
{0,2} is an ideal of Z_4: there is at least one too many negatives in your last sentence.
Look, let's just write down what we know:
suppose we have a ring R and the only ideals in R are 0 and R.
Let's suppose that x is a non-identity element in R and consider the ideal xR, since 1R=R, and this tells us nothing about R.
xR is either 0 or R.
Since rings normally assumed to have identities you can now proceed to deduce some things.
My bad again. I meant to say that Z4 IS an ideal. Thanks.
Am I missing something or does the trivial ring R = {0} not count??
R is a commutative ring.
R is not a field since it does not have a nonzero identity.
The only subrings of R are {0} and R.
Weird.
Most people require a ring to have a multiplicative identity. Why is it weird that there are (degenerate) counter examples. If you follow my suggestion you will find all of the counter examples.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
