Does filament size or resistance affect the brightness of a lightbulb?
The discussion centers on the relationship between filament size, resistance, and light bulb brightness. It is established that a filament with lower resistance allows more current to flow, resulting in increased brightness due to higher power output, as power is calculated by the formula P=V*I. While smaller filaments typically have higher resistance, which can lead to less brightness, the overall effect depends on the voltage supplied. A larger filament can indeed produce a brighter light if it allows for more current without exceeding the voltage limit. Understanding resistive heating is crucial to grasping these concepts fully.
southern69
Does anyone have a clear understanding on the relationship between the filament size of a lightbulb and the wattage? I was under the impression that resistance causes the filament to heat up and glow, so the more resistance the brighter the light bulb. A filament with more resistance, then, would have to be smaller. However I have read that a larger filament causes a bulb to grow brighter. Is this true, and why?
Thanks
It is true, because the wall is in essence a constant voltage source. Given a constant voltage and a purely resistive load (a decent approximation), a filament with half the resistance will allow twice the current through. Because power is V*I, for a constant V and twice the I (current), you will have twice the power.
Thanks. But are you saying that more current causes the filament to glow brighter? If this is true could you please try and explain it to me. (sorry)
google "resistive heating".
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
12K
