Fill Balloons Homework: Max # People for Bday Party Balloon
The problem involves calculating the maximum number of balloons that can be filled with helium from a cylinder, given specific pressures and volumes. The context is related to gas laws and the behavior of gases under pressure.
  • Participants discuss the application of the ideal gas law and the relationship between the pressures and volumes of the helium in the cylinder and balloons. There are attempts to verify calculations and check for errors in the original values used.
The discussion includes attempts to clarify the calculations and assumptions made regarding the pressures and volumes. Some participants suggest that the original poster may have made a mistake in the pressure value used, while others provide insights into the implications of the calculations on the number of balloons that can be filled.
There is mention of a potential error in the pressure value used in the calculations, as well as a note about the fraction being inverted. The original poster expresses confusion over the discrepancy between their answer and the expected result.
MadTay
A clown at a birthday party has brought along a helium cylinder, with which he intends to fill balloons. When full, each balloon contains 0.00260 m3 of helium at an absolute pressure of 1.10 x 105 Pa. The cylinder contains helium at an absolute pressure of 1.80 x 105 Pa and has a volume of 0.00310 m3. The temperature of the helium in the tank and in the balloons is the same and remains constant. What is the maximum number of people who will get a balloon?
Once I entered my first attempted answer, it gave me this as a hint: http://edugen.wileyplus.com/edugen/courses/crs7924/art/qb/qu/c14/EAT_12266037659380_3045928466969894.gif
PV=nRT[/B]
As stated above, since nRT does not change for either the cylinder or the balloons:
PVballoon/PVcylinder=number of balloons
(0.00260)(1.1x105)/(0.00310)(1.8x107)=195.1048951
So I entered 195 as the maximum number of people that would get a balloon, but it told me my answer was incorrect.
I worked another sample in the book with the exact same problem just different numbers, and I got the correct answer, so I am very lost.
After the last balloon is filled, will the cylinder be empty?
Please check your original numbers. The pressure in the tank and volume in the tank is such that it looks like it might fill about 2 balloons. The pressure in the tank needs to be much higher and/or its volume needs to be much larger to fill very many balloons. (I see you used a tank pressure of 1.8*E+7 rather than 1.8*E+5 in your calculation. You also have your fraction upside-down))
I am so sorry, I made a mistake, the original number is supposed to be 1.8*E+7 not 1.8*E+5. I also typed my fractions upside down, but when I did the calculations my fractions were rightside up.
The 195 looks like the correct answer. Once the tank reaches a pressure of 1.1 E+5 Pa (after about 193 balloons), it will not be able to fill up any more balloons, but that is a very minor detail, and 195 is a good answer.
  • · Replies 16 ·
10K
  • · Replies 25 ·
12K
12K
