Final Velocity of a Spaceship Approaching Earth from Infinity Due to Gravity
The problem involves determining the final velocity of a spaceship approaching Earth from an infinite distance, assuming the Earth is at rest and only gravitational forces are acting on the spaceship.
  • Participants discuss the setup of the problem using gravitational force equations and integration techniques. There are questions regarding the limits of integration and the correct application of signs in the equations.
Some participants affirm the original poster's approach and suggest proceeding with the integration. Others caution about potential sign errors and emphasize the importance of consistent units when applying the gravitational constant.
There is a mention of the radius of the Earth in kilometers and the need for clarity on the units used for gravitational calculations. The discussion reflects uncertainty about the limits of integration and the correct formulation of the equations involved.
Luke1121
Assuming the Earth is at rest and alone in the universe what speed would a spaceship arriving at the surface of Earth from an infinitley large distance be if the speed at infinity= 0 and acceleration is caused only by gravity
[itex]F= \frac{GmM}{x^2}[/itex]
Also using the chain rule [itex]a=v\frac{dv}{dx}[/itex]
well I set ma equal to the force due to gravity so
[itex]v\frac{dv}{dx}= \frac{GM}{x^2}[/itex]
seperating the variables gives [itex]vdv=\frac{GM}{x^2}dx[/itex]
then
[itex]\int vdv=GM\int x^{-2} dx[/itex]
would the limits of integration need to be from infinity to the surface of the earth, or am i on the wrong track all together?
You're doing fine. Just do the integral as you suggest.
You're on the right track. But you might need to be careful with signs. [Edit: I see haruspex beat me :smile:]
Ok, then doing the indefinite integral gives [itex]v=\sqrt{\frac{2GM}{x}} + C[/itex]
but I'm not sure about the limits, would it be [itex]\frac{1}{2}v^2=-GM\int_{\infty}^{6370}x^{-2}[/itex]
where 6370 is the radius of the Earth in km?
Thanks
Thanks
The limit is the radius of the Earth. What units you use are up to you, so long as you are consistent. I would think your value for G assumes m, not km.
I think you have a sign wrong above. The minus sign should only appear after performing the integral.
  • · Replies 39 ·
