Final Velocity of Mass on Frictionless Incline
The discussion revolves around calculating the final velocity of a 9 kg mass sliding down a frictionless incline after being released from a compressed spring. The spring has a constant of 3.6 N/cm and is compressed 39 cm. The incline has a height of 36 cm and an angle of 20°, with a frictional section of 0.6 m and a coefficient of friction of 0.4. Participants express confusion over the correct application of energy conservation equations, particularly regarding the work done by non-conservative forces and the role of the spring's compression. The consensus suggests that incorporating the spring's potential energy directly into the energy conservation equation may simplify the calculations.
dgl7
A spring with a spring-constant 3.6 N/cm is compressed 39 cm and released. The 9 kg mass skids down the frictional incline of height 36 cm and inclined at a 20◦ angle. The acceleration of gravity is 9.8 m/s^2. The path is frictionless except for a distance of 0.6 m along the incline which has a coefficient of friction of 0.4 .
What is the final velocity of the mass?
2. RELEVANT EQUATIONS
Ko+Uo+Wnc=U+K
kinematic equations
ma=kx
3. MY ATTEMPT
I tried kx=ma-->
(3.6)(.39)=(9)a
a=.156
I put that into the kinematic equation v^2 = vo^2 + 2a(X - Xo)
v^2=(0)^2+2(.156)(.39)
got v=.3488266045 m/s (note: this would be vo for the overall equation and v only for the compression of the spring)
I put that into Ko in the Ko+Uo+Wnc=U+K equation-->
.5(9)(.3488266045)^2+(9)(9.8)(.36)+[(.4)(9*9.8*cos20)](.6)(cos20)=0+.5(9)v^2
solved for v and got 3.366216946 m/s but that isn't right...I think there is something wrong with the nonconservative work, but I'm not sure what...
I'm wondering about the 39 cm where the spring pushes the block. Is that 39 cm part of the incline? If so, it makes your kx=ma calc incorrect because a component of mg will also be acting. Might be easier to just include a 1/2kx^2 term in your conservation of energy equation.
Also, the cos(20) on the end of the friction term seems odd to me. What is it for?
Yes that would make a lot more sense to just use Uspring+Ugravitational+Wnc=K. I didn't/don't know how to solve for Wnc, so I just used Ffriction*r*costheta, which brought me to the cos20...
It says "distance of 6 cm along the incline" so it is just Ff*.06 with no cos(20). Keep in mind the faint possibility that it runs out of energy somewhere in the friction stretch.
