Find a function of two variables with these propertes. .
Vampire
Find a function of two variables whose level curves are parabolas with vertex (0,0) with a hole in the parabolas at the origin.
No special equations come to mind.
4ay=x2 may be a little useful.
The first thing I thought of was y=x3/x, but that doesn't include the third variable. I know the parabolas can have any value for a or face any direction, but I do not know how to include z so that the function will remain having level curves as stated.
Are there any other functions with these properties? Any input will be appreciated.
so i assume by z you mean the function z = F(x,y) we are trying to find?
so we have the level curves of z = F(x,y), given by F(x,y) = c, for some constant a, are given by y = ax^2, for some constant a.
What if we set the constants the same?
F(x,y) = a --> y = a^x2
hopefully this will get you started...
a few other things to consider.
- The solution for F(x,y) is not uniquie - can you find the full family of solutions?
- The gradient of F(x,y) will be perpindicular to a level curve at any point, useful check
- The levels curevs have a "hole" at (0,0), why & what does this imply for F(x,y)?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
