ShadowFX
- 11
Two insulated wires, each 2.4 m long are taped together to form a two wire unit that is 2.4 m long. One wire carries a current of 7.00 A; the other carries a smaller current I in the opposite direction. The two wire unit is placed at an angle of 65.0 degrees relative to a magnetic field whose magnitude is 0.360 T. The magnitude of the net magnetic force experience by the two wire unit is 3.13 N. What is the current I?
A square coil and a rectangular coil are each made from the same length of wire. Each contains a single turn. The long sides of the rectangle are twice as long as the short sides. Find the ratio of torque of the square over the torque of the rectangle of the maximum torques that these coils experience in the same magnetic field when they contain the same current
Two long, straight parallel wires are separated by a distance of one meter. They carry currents in opposite directions, and the current in wire A is one-third of that in wire B. On a line drawn perpendicular to the wires, find the point where the net magnetic field is zero. Determine this point relative to wire A.
I have no clue at all how to do these questions or what unit they're from, I'm doing some studying and reviewing and these were on our last assignment but i didnt do them because i didnt know how... can someone give me some forumlas or something i could use to approach it?
