Find a vector normal to the plane at (2,1,7)
mharten1
This is a two part problem
A) Find a vector normal to the plane at (2,1,7)
B) Find a vector normal to the plane tangent to the paraboloid at (2,1,7)
Plane: z = x + y +4
Paraboloid: z = x^2 +3y^2
I'm not sure where to start. I know that a vector normal to the plane is <1,1,-1>, but that isn't at (2,1,7). Any help?
A plane has the same normal everywhere, doesn't it?
That's what I thought at first. But it seems too easy to be the solution to both questions. I'm going to read over the section again and see if I can find anything that will be useful.
It's not the solution to the second question. Think about using the gradient.
I was able to solve it, thank you. :)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
