Find area contained by the curve
  • Thread starter Thread starter andrey21
    Area Curve
andrey21
FInd the area contained by the curve and the x axis
y = (2x-7)(x+4)
I don't know really where to start all I have done is multiply out the brackets like so
y = 2x^(2) + x - 28
Will the curve cross the x-axis at x = -4 and x = 7/2 ??
y = (2x-7)(x+4)
y = 2x^(2) + x - 28
Yes, of course. Since you are supposed to find the area between this curve and the x axis, you will need to set up a definite integral.
Ok so i set up the definite integral:
Next I integrated the equation to give me:
2/3 x^(3) +x^(2)/2 -28x
I then subst in values and gave me a final value of:
-140 5/8
Is this correct? Sorry bad formatting on integration
For what you did, that answer is correct, but what you did isn't correct. The area should never be negative. The region whose area you are finding lies beneath the x-axis, so the area of your typical area element is (0 - (2x2 + x - 28))\Delta x.
Ah I see but it will just come out with the same answer but positive if I adopt the method u suggest?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
