Find Bohr Radius from Approximate Potential Energy
The discussion focuses on deriving the expression for the Bohr radius (a0) using the potential energy approximation V(r) = -e2/r. The total energy of the electron is expressed as E(ȳ) = (ħ2)/(2mȳ2) - (e2)/(ȳ), where ȳ represents the mean radius. By minimizing this energy function, the Bohr radius is calculated as a0 = (n2ħ2)/(me2), yielding a value of approximately 5.24 x 10-9 cm for the ground state (n=1). The discussion highlights the importance of correctly applying the uncertainty principle and the need for a more comprehensive approach to the problem.
  • Understanding of quantum mechanics principles, specifically the uncertainty principle.
  • Familiarity with potential energy functions in atomic physics.
  • Knowledge of kinetic energy calculations for particles in confined systems.
  • Basic grasp of commutator relationships and compatible operators in quantum mechanics.
  • Study the derivation of the uncertainty principle in quantum mechanics.
  • Learn about potential energy functions and their applications in atomic models.
  • Explore the concept of minimizing energy functions in quantum systems.
  • Investigate commutator relationships and their significance in quantum mechanics.
Students and educators in quantum mechanics, physicists working on atomic models, and anyone interested in the mathematical derivation of fundamental constants like the Bohr radius.
Mattszo
Determine an expression for the Bohr radius (a[itex]_{0}[/itex] from the following approximation. The electron moves to the nucleus to lower its potential energy,
V(r) = -[itex]\frac{e^{2}}{r}[/itex]
If the electron is in domain 0[itex]\leq[/itex]r[itex]\leq[/itex][itex]\bar{r}[/itex], then we may write Δp≈[itex]\frac{\hbar}{\bar{r}}[/itex], with corresponding kinetic energy [itex]\frac{\hbar^{2}}{2m\bar{r}^{2}}[/itex]. With this information estimate a[itex]_{0}[/itex] (Bohr radius) by minimizing the total energy.
Uncertainty ΔpΔx≈[itex]\frac{\hbar}{2}[/itex]
[itex]\bar{r}[/itex] is the Mean of r -------> (I think)
[itex]\hat{H}[/itex][itex]\varphi_{n}[/itex]=E[itex]_{n}[/itex][itex]\varphi_{n}[/itex] or with x-hat and x
For an electron moving with momentum p 2[itex]\pi[/itex]rp=nh
E = K.E + V(x)
[[itex]\hat{A}[/itex], [itex]\hat{B}[/itex]]=[itex]\hat{A}[/itex][itex]\hat{B}[/itex]-[itex]\hat{B}[/itex][itex]\hat{A}[/itex]
[[itex]\hat{A}[/itex], [itex]\hat{B}[/itex]]=0 if they they commute
[[itex]\hat{x}[/itex], [itex]\hat{p}[/itex]]=i[itex]\hbar[/itex]
And I have no idea where this equation came from but I found it in the book and used it for my solution:
[itex]\frac{e^{2}}{r}[/itex]=[itex]\frac{p^{2}_{\vartheta}}{mr^{2}}[/itex]=[itex]\frac{n^{2}\hbar^{2}}{mr^{2}}[/itex] where e is the electric charge of the electron and p[itex]_{\vartheta}[/itex]=mr[itex]^{2}[/itex][itex]\dot{\vartheta}[/itex]
E = [itex]\frac{p^{2}_{\vartheta}}{2m\bar{r}^{2}}[/itex]-[itex]\frac{e^{2}}{\bar{r}}[/itex] ... i
From the "Centripetal Condition" (The equation I got from the book) (r)[itex]\frac{e^{2}}{r^{2}}[/itex]=(r)[itex]\frac{p^{2}_{\vartheta}}{mr^{3}}[/itex]=[itex]\frac{p^{2}_{\vartheta}}{m\bar{r^{2}}}[/itex] ... ii
sub ii into i
E = -[itex]\frac{p^{2}_{\vartheta}}{2m\bar{r}^{2}}[/itex] ... iii
Now from Centripetal Condition:
r=[itex]\frac{n^{2}\hbar^{2}}{me^{2}}[/itex] where p[itex]_{\vartheta}[/itex]=n[itex]\hbar[/itex] ... iv
Put iv into iii
E = -[itex]\frac{p^{2}_{\vartheta}}{2m}[/itex]([itex]\frac{me^{2}}{n^{2}\hbar^{2}}[/itex])[itex]^{2}[/itex]=-[itex]\frac{me^{4}}{2n^{2}\hbar^{2}}[/itex] and let ℝ=[itex]\frac{m_{e}e^{4}}{2\hbar^{2}}[/itex]=13.6eV
Then E[itex]_{n}[/itex]=[itex]\frac{ℝ}{n^{2}}[/itex]
So for n=1, which is the lowest possible state of potential energy, E[itex]_{1}[/itex]=13.6eV
and for n=1 from equation iv
r[itex]_{1}[/itex]=a[itex]_{0}[/itex]=[itex]\frac{n^{2}\hbar^{2}}{me^{2}}[/itex]=5.24x10[itex]^{-9}[/itex]cm=Bohr's radius
The problem is this was too straightforward and simple. I did not correctly use the mean value of [itex]\bar{r}[/itex], because it is a function and I am to find an expression for the Bohr radius.
I used very little of the information provided.
Also I just assumed the lowest energy state, whereas the question says that the electron just goes to a lower energy state.
Also this question is in the chapter where they define the commutator relationships and compatible operators, and really the whole chapter is about that. I find it fishy the solution I provided doesn't use any of that chapters material.I need a new approach to this problem and am out of ideas. Please help.
The idea here is that the electron is confined to a region of size ##\bar{r}##, so applying the uncertainty principle gives you an estimate of the magnitude of its momentum, namely ##p \approx \hbar/\bar{r}##, and therefore of its kinetic energy. The total energy of the electron is thus given as a function of ##\bar{r}## by
$$E(\bar{r}) = \frac{\hbar^2}{2m\bar{r}^2} - \frac{e^2}{\bar{r}}.$$ The problem is simply asking you to find the value of ##\bar{r}## for which the total energy of the electron is minimized.
I see it now, thank you!
  • · Replies 30 ·
