Finding Coordinates of A and B in an Equilateral Triangle
  • Thread starter Thread starter adjacent
    Coordinates
The discussion focuses on finding the coordinates of points A and B in an equilateral triangle with vertex O at (0,0). The participants derive equations based on the distances OA, OB, and AB, leading to simultaneous equations involving a and b. They explore methods such as substitution and elimination to solve for these variables, with one participant eventually finding approximate values for a and b. The conversation also touches on the use of complex numbers and trigonometric identities as alternative approaches. The problem is noted to have two potential solutions based on the geometric configuration.
adjacent
The points O,A and B are vertices of an equilateral triangle. Find a and b
O=(0,0)
A=(a,11)
B=(b,37)
##c^2=a^2+b^2##
Let AB =c
Then ##c=\sqrt{(a-b)^2+(11-37)^2}=\sqrt{(a-b)^2+676}##
Since it is an equilateral triangle, OA and OB is also =c
So ##c=\sqrt{11^2+a^2}##
##c=\sqrt{37^2+b^2}##
##\sqrt{(a-b)^2+676}=\sqrt{11^2+a^2}=\sqrt{37^2+b^2}##
I have got to know that ##a^2+b^2=1248##, but what next?
I need to find at least one variable to find the other. :confused:
You have two independent equations:
##\sqrt{(a-b)^2+676}=\sqrt{11^2+a^2}## and
##\sqrt{(a-b)^2+676}=\sqrt{37^2+b^2}##, for example.
Square the equations, and solve for a, b.
ehild
You've used two equations for the length of c. There is a third one, can you see it?
It is not independent of the other two.
ehild
I have a question.
Why is squaring both sides the same as multiplying both sides by something?
For example,we have an equation such that ##a=b##
If we multiply both sides, the equation remain unchanged, ##2a=2b## --> ##a=2b/2##--> ##a=b##
Again we have an equation such that ##a=2b##
If we square both sides, --> ##a^2=(2b)^2## --> ##a \times a=2b \times 2b=4 \times b \times b## --> ##a=(4 \times b \times b)/a## :confused:
If I do it another way,it remains unchanged: ##a=2b##--> ##a^2=(2b)^2## --> ##a=\sqrt{(2b)^2}##--> ##a=2b##
:confused:
Squaring both sides of an equation is not the same as multiplying both sides with something. The equation stays true, but squaring might introduce false roots. You have to check at the end.
How would you isolate the unknowns without squaring?
If you have the equation a=b and you square both sides, a2=b2, you can isolate one variable by taking the square roots. You get the solution a=±b. a=-b is false.
ehild
Ok, nevermind
I have got this result after rearranging,squaring etc.
##b^2-2ab+676=11^2##
##a^2-2ab+676=37^2##
Before solving the simultaneous equation,I strongly believe this should become
##b^2=11^2##
##a^2=37^2##
but I don't know how. It's not possible to just cancel out the terms since they do not have opposite signs.
Check. Plug in the values and see what you get.
ehild
ehild
It's wrong -_-
I have never solved equations of this kind. I don't know what to do when I have 3 variables(##-2ab,b^2 and a^2##) :confused:. Any hints?
You have two unknowns, a and b. Isolate b from the second one and substitute the expression for b into the first one. Yo get an equation for a alone.
ehild
Likes 1 person
I got a wrong answer:
##b=\frac{a^2-693}{2a}##
##a^2-2a. \left(\frac{a^2-693}{2a} \right)+676=37^2##
Solving for a, we get ##a \in R## :confused:
You substituted back into the same equation.
Substitute into
ehild
Likes 1 person
Substitute into
ehild
Ah,
I get the answer as
a=36.37
b=8.66
I solved this using my computer, I should do it myself too. Let me try:
Isolating b
##a^2-2ab=693##
##b=\frac{693-a^2}{-2ab}##
##=\frac{a^2-693}{2a}##
Plug it into the first equation
##b^2-2ab+676=121##
##\left(\frac{a^2-693}{2a} \right)^2-2a\left(\frac{a^2-693}{2a} \right)=-555##
After doing many steps, I got to this:$$-3a^4+3606a^2+480249=0$$
I am not sure what I should do after this step :confused: , some kind of 4th power equation? :eek:
Look carefully at the equation you wind up with. It's a quadratic in a^2.
Why should it be a quadratic equation? We have a ##-3a^4## there.
You really don't see what you get when you put ##a^2 = x##?
Likes 1 person
oh, I never thought of it :shy:
This is the first time I have solved such a scary equation-Feeling happy
Thanks guys
btw, can't we solve it using elimination method?
Thanks guys
Standard trick. Whenever you have an equation in even powers ##a^{\pm 2k}## you can put ##a^2 = x## and get an equation involving ##x^{\pm k}##.
As for 'elimination': yes, you can use the equality ##a^2 + 11^2 = b^2 + 37^2## to write ##b## in terms of ##a##. Since your drawing indicates ##b \geq 0## there will not (at this stage) be a problem of choosing the correct sign: ##b = \sqrt{a^2 - 1248}##. Put that into the equation ##a^2 + 11^2 = (a-b)^2 + 676##, so you have eliminated ##b##. However, the result is not a very nice equation for ##a##.
No. I mean can we use the elimination method for solving these two equations?(Simultaneous equation)
##(a-b)^2+676}=11^2+a^2##
##(a-b)^2+676=37^2+b^2##
There is a much shorter solution. Use complex numbers. :)
Do you see that the following equation holds?
$$b+37i=(a+11i)e^{i\pi/3}$$
Just compare the imaginary and real parts.
Likes 2 people
##(a-b)^2+676=11^2+a^2##
(Error corrected above---you had an unmatched '}').
Which message are you responding to? Please use the 'quote' button, so such confusion is eliminated.
My previous post did, indeed, show how to use the 'elimination' method on those very two equations. However, it first used the fact that the two right-hand-sides are equal---because the left-hand-sides are---to get an equation that makes the elimination much, much easier.
It is very clever, Pranav!
ehild
ehild
Thank you, sir! :blushing:
adjacent said:
I have a question.
:confused:
I think about "squaring both sides" in terms of multiplication with substitution. In your example you have ##a = 2b##. If we multiply the equation by ##a##, and this yields ##a \cdot a = a (2b)##. We can substitute the ##a## on the right-hand side of the equation with ##a = 2b##. Now, ##a\cdot a = (2b)\cdot (2b)##, or simply ##a^2 = (2b)^2##.
Note that where you wrote :confused:, you can substitute ##a = 2b##. Then ##a = (4 \times b \times b) / 2b = 2b##.
I hope that helps.
Likes 1 person
ehild
It's very clever but it's far too advanced for me :cry:
Ray Vickson, I am asking whether Elimination method can be used for solving the two simultaneous equation. I used the substitution method where we solved the second equation for b and substituted it in the first equation.
In the elimination method,we do this:
If we have two equations ##x+y=1## and ##x-y=3##
We multiply the coefficient of the first term in the first equation with the second equation and vice versa.
I am having trouble here because the first two terms are different and the ##b^2##,##a^2## and ##-2ab## seems to act like three different variables. Hope you understand what I am trying to say :redface:
I hope that helps.
I see, that helped. Thanks :smile:
Haven't you studied complex numbers yet?
Or have you studied how the components of a vector change when turned by an angle θ round the origin?
Or the summation laws for trigonometric functions?
ehild
Yes
No. But I think it's pretty obvious.It's just a right angle triangle whose hypotenuse's length remains constant. So I can use that fact to find the other two sides. :wink:
I think I know two of them.
##\sin(a+b)=\sin(a)\cos(b)+\cos(a)\sin(b)##
##\cos(a+b)=\cos(a)\cos(b)-\sin(a)\sin(b)##
Heared it from a calculus lecture I watched some days ago
adjacent said:
Yes
Heared if from a calculus lecture I watched some days ago
Very good. Look at the picture. You find two right triangles, the red one having angle Φ with the x axis, the blue one has angle θ. θ=60°+Φ.
If the sides of the equilateral triangle are of length C, C cos(θ)=b, C sin(θ)=37 Ccos(Φ)=a, Csin(Φ)=11
θ=60°+Φ, apply the addition laws. You know that cos60°=1/2, sin/°=√3/2.
Csin(60°+Φ)=Csin(60°)cos(Φ)+Ccos(60°)sin(Φ)→(√3/2)a+(1/2)11=37
Do the same with Ccos(θ):
C cos(60°+Φ)=Ccos(60°)cos(Φ)-Csin(60°)sin(Φ)→(1/2) a-(√3/2)11=b
Solve.
ehild
Likes 1 person
ehild said:
θ=60°+Φ
How do you know this?
EDIT: Oh I got it, How dumb I am !
This also yields a simultaneous equation right?
Anyway, thank you so much! I learned a lot from this thread. Thanks everyone!
  • #31
It yields the equations in bold in my previous post. See if you get the same ones, by applying the summation laws.
The equations are very easy to solve: There is only one unknown, a, in the first one.
ehild
Likes 1 person
  • #32
I get the same thing too. Thanks for helping me.
  • #33
It can be also done by using Coni's method. BTW, adjacent you're 15 ?
  • #34
I just want to point out that this problem has two possible solutions: I only saw one posted. You can see this by drawing lines to represent the possible points for A and B. In other words, ##(a, 11)## is somewhere on the line ##y = 11##. The point ##(b, 37)## is somewhere on the line ##y = 37##. Since the distance from O to A and from O to B is the same, we can draw a circle with radius ##r## and center at O. The intersections show the possible solutions. One is in QI and the other is in QII.
  • #35
Yes, by distance formula it's obvious that there are two solutions. To reduce the calculation part, I preferred Coni's method(in complex numbers), which also offers two solutions.z1/z2= eiπ/3
In this case |z1|=|z2|...being an equilateral triangle.
  • #36
Yes, but the given picture suggest position in the first quadrant.
ehild
  • #37
ehild
  • #38
ehild
So Coni's method will offer one solution as z1/z2=eiπ/3.
Other will depend on quadrants due to the term eiπ/3 (sign of angle). That won't matter as it is first quadrant related.
