Find electric field intensity/density with given potential difference
The discussion revolves around calculating electric field intensity and charge density related to a potential difference in a system involving spheres, specifically focusing on the relationship between voltage, charge, and electric field strength.
  • Participants discuss the application of equations relating potential difference to charge and electric field, while questioning the assumptions about the nature of the spheres involved (conducting vs. non-conducting).
There is an ongoing exploration of different interpretations regarding the charge distribution and the nature of the spheres. Some participants have provided insights into relevant equations and highlighted the importance of correct terminology for charge density, but no consensus has been reached on the assumptions made.
Participants are navigating the implications of whether the sphere is conducting or non-conducting, as well as the uniformity of charge distribution, which affects their calculations and interpretations.
vboyn12
In photo below. (help me please)
I don't know whether the relevant equation can help because I haven't figure out any idea yet.
Hi,
PF rules (please read them) only allow us to help if you post an attempt at solution.
What have you learned so far, that you might use here?
BvU said:
Hi,
Hi, I try to solve part a and b and i posted below, can you have a look at it?
OK, so you use $$ V_1-V_2 = 12\ \text{V}\ = {Q\over 4\pi\varepsilon_0}\left ( {1\over r_1} - {1\over r_2} \right ) $$(which I suppose might make a good entry in the list of relevant equations :rolleyes: )
And then (another one !) $$ \left | \vec E(r_s) \right | = {Q\over 4\pi\varepsilon_0}\ {1\over r_s^2} $$so that $$ \left | \vec E(r_s) \right | = { 12\ \text{V}\ \over \ \displaystyle {1\over r_1} - {1\over r_2}\ } \ {1\over r_s^2} =
12\ \text{V}\ {1\over r_2-r_1}\;{r_1 r_2\over r_s^2 }$$(thus avoiding calculator and rounding errors!) which agrees with your result once we learn to read your handwritten 4 that looks scaringly similar to a 9 :nb)
I wouldn't quote 6 digits if the ##r## are given in only 1 digit, but that's a matter of taste.
Be sure to use the right ##\varepsilon## if you quote so many digits (I get ##|D| = 1.312 \ 10^{-9} ## !) and do use units ! :mad:
For part c) you need to know that at least the inner sphere is non-conducting !
Sorry about the unit :D. For part (c), is that the value of charge Q found in part (a) equal to the surface charge density multiply by the surface area which is 4pi*r^2? If that is right I get rho(s)=11,789 nC/m^2
Up to you: the usual symbol for surface charge is ##\sigma\;##, and ##\rho\ ## is usually volume charge density. Hence my speculation in post #5.
No problem for me, but it can save you brownie points with graders...
Do you get the same result as mine for part (c)?
What does it say in the actual problem statement ? Is it a conducting sphere or not ?
It is not conducting
And is the charge uniformly distributed over the volume ?
(That is my assumption -- and in that case I don't agree with your answer)
can you give me your solution corresponding to your assumption, please?
You mean calculate the charge density in a uniformly charged unconducting sphere with a given total charge ##Q\ ## :wink: ?##\ ##
Oh, I see :D. Thank you a lot
  • · Replies 22 ·
