Find maximum thrust of a rocket blasting off
The discussion focuses on calculating the maximum vertical thrust of a rocket with a mass of 2.49×104 kg, which accelerates at 15.42 m/s2. The rocket must reach the sound barrier speed of 330 m/s without exceeding the maximum tension of 37.3 N in a supporting wire for a 14.5 N instrument. The calculations reveal that the rocket reaches a height of 3530 m when breaking the sound barrier, and the thrust must be determined by accounting for both gravitational force and the required net force for acceleration.
  • Understanding of Newton's laws of motion
  • Basic knowledge of kinematics
  • Familiarity with thrust and gravitational force concepts
  • Ability to perform calculations involving force, mass, and acceleration
  • Calculate the thrust force using the equation F = ma, incorporating gravitational force
  • Explore the relationship between thrust and weight in vertical motion
  • Study the principles of rocket propulsion and thrust generation
  • Learn about the effects of acceleration on tension in supporting structures
Students studying physics, aerospace engineers, and anyone interested in rocket dynamics and thrust calculations.
RUphysics3
A 2.49×104-kg rocket blasts off vertically from the Earth's surface with a constant acceleration. During the motion considered in the problem, assume thatg remains constant. Inside the rocket, a 14.5-N instrument hangs from a wire that can support a maximum tension of 37.3 N .
I found that :
Acceleration = 15.42 m/s^2
Find the minimum time for this rocket to reach the sound barrier (330m/s) without breaking the inside wire.
The answer to this was 21.4 .
How far is the rocket above the Earth's surface when it breaks the sound barrier?
3530 m.
Now I have to find the maximum vertical thrust of the rocket engines under these conditions.
I tried using F=ma and some basic kinematics.
Using F=ma...
i tried F=(2.49x10^4) * 15.42 . This wasn't correct.
Tension acts on the instrument and on the rocket. (Downwards on rocket and upwards on the instrument) Let acceleration of rocket be ##a##. Since the string is inextensible, the instrument will also have same acceleration. Write Newtons law equation for both rocket and instrument.
Is this the net force on the rocket or the thrust force?
Well it's a vertical launch..So wouldn't it be the same thing? the only component is in the y direction.. I don't really understand thrust that well. I think it's something like thrust comes out the bottom of the rocket and propels it upwards so the thrust acts upwards? I really don't know
What do you mean?
So for the rocket it would be F=(2.49x10^4) * 15.42
For the instrument.. F=(14.5N/9.81) * 15.42 ? Now what?
Thrust is the exhaust gas pushing upward on the rocket. Gravitational force (weight) is Earth pulling downward on the rocket.
So weight would be the mass times 9.8. But i did mass * acceleration..Okay.. so should I find weight of the rocket and subtract that from the upward thrust?
To get the net force, yes.
9K
  • · Replies 32 ·
14K
