Find Min Speed to Jump 8 Cars: 2D Homework Solution
  • Thread starter Thread starter endeavor
    2d Speed
To determine the minimum speed required for a stunt driver to jump over 8 cars, the problem involves calculating the initial velocity needed to clear a horizontal distance of 20 meters from a ramp 1.5 meters high. The equations of motion are applied, leading to the initial velocity formula that incorporates the takeoff angle. The user initially calculated a speed of 2.05 m/s for the upward-tilted ramp scenario, but recognized an algebraic error in placing gravitational acceleration in the denominator instead of the numerator. The correct approach involves ensuring proper application of the equations to find the accurate initial velocity for both scenarios. The discussion emphasizes the importance of careful algebraic manipulation in physics problems.
endeavor
A stunt driver wants to make his car jump over 8 cars parked side by side below a horizontal ramp (Fig. 3-46). (a) With what minimum speed must he drive off the horizontal ramp? The vertical height of the ramp is 1.5 m above the cars and the horizontal distance he must clear is 20m. (b) What is the new minimum speed if the ramp is now titled upward, so that "takeoff angle" is 10 degrees above the horizontal, and nothing else is changed?
http://img181.imageshack.us/img181/6396/chp3pro46sk5.th.png
I need help on part b.
y0 = 1.5m
x = 20m.
Z = 10 degrees
x = (v0 cos Z) t
0 = y0 + (v0 sin Z)t - 0.5*g*t2
I have two equations in two variables, t and v0. So I solved for v0:
v_0^2 = (\frac{x^2}{2g\cos^2 Z})(\frac{1}{y_0 + x \tan Z})
So, plugging in, I got 2.05 m/s for v0. But that has to be wrong, especially since my answer in (a) is 36m/s.
What am I doing wrong?
I know what I did wrong. I put g in the denominator, but it should be in the numerator...
algebra mistake... the g should be placed on the numerater...
How did you develop the equation to solve for the initial velocity?
