Find Normal and Tangential components of accelaration
The discussion focuses on finding the normal and tangential components of acceleration for a particle described by the polar equation of motion. Participants express confusion over deriving the necessary components and equations, particularly regarding the relationships between the tangent vector, normal vector, and curvature. Key equations discussed include the definitions of the tangent vector and normal vector, as well as the curvature formula. The conversation highlights the importance of correctly applying derivatives and understanding the distinction between vector and scalar forms. Ultimately, clarity is achieved on the relationships between the vectors and their magnitudes, leading to a better understanding of the problem.
RyanH42
The Particle moves in the plane in a such a way that its polar equation of motion is ## \vec{R}=t\vec{i}+(t^2+1)\vec{j}##.
a)What are its normal and tangential components of accelaration any time t ?
b)Whats the curvature of path any time t ?
##\vec{a}=d^2s/dt^2\vec{T}+k\vec{N}d^2s/dt^2##
##k=dθ/ds##
I couldn't find ##ds/dt## I tried but I stucked.
I have no idea to find k but I couldn't find s
One note to avoid confusion. The \frac{ds}{dt} you wrote is the magnitude of the velocity, whereas the \frac{d\vec{R}}{dt} is its vector.
Where did you get that equation for k?
ChrisVer said:
One note to avoid confusion. The dsdt\frac{ds}{dt} you wrote is the magnitude of the velocity, whereas the dR⃗ dt\frac{d\vec{R}}{dt} is its vector.
Yeah I remember equations false I checked again it was ##d\vec{R}/ds##
ChrisVer said:
Where did you get that equation for kk?
I remembered that false too it will be ##k=dθ/ds##
And Is this equation true every time ? ##d\vec{T}/dθ=\vec{N}## (N is not unit vector).I now its a stupid qustion but the derivation of it come to me not generally true
Let me put it else... what does \theta stand for?
you can look the graph
I got the idea in 21:49 look the magnitude of ##d\vec{T}/ds=dθ/ds=k## Is that mean the magnitude of ##\vec{N}## equal ##k##.I am confused one time he says ##d\vec{T}/dθ=\vec{N}##(In 10:49) now he says ##d\vec{T}/ds=\vec{N}## Is it a special case which I mentioned ?
RyanH42 said:
N→\vec{N} equal k
The magnitude of \vec{N} is unity (it's a unit vector). k= \Big| \frac{d\vec{T}}{ds} \Big| is some number and so:
\vec{N} = \frac{d \vec{T}}{ds} \Big/ \Big| \frac{d\vec{T}}{ds} \Big| has magnitude equal to 1.
Likes RyanH42
First of all, did you find the tangent and normal vector to the acceleration?(question a)
RyanH42 said:
I am confused one time he says dT→/=N→d\vec{T}/dθ=\vec{N}(In 10:49) now he says dT→/ds=N→d\vec{T}/ds=\vec{N} Is it a special case which I mentioned ?
It is just because the normal vector is:
\vec{N} \equiv \frac{d\vec{T}}{dt} \Big/ \Big|\frac{d \vec{T}}{dt} \Big|
Likes RyanH42
Tangent vector is \vec{T} = \frac{d \vec{R}}{dt} \Big/ \Big| \frac{d\vec{R}}{dt} \Big| so Its ##\vec{T}=1/√5\vec{i}+2/√5t\vec{j}##.Normal vector will be then ##\vec{N}=\vec{j}##
beg me but I didnt understand first ds (in your #8 post) now we can use dt. Whatever we want we can use that equation I guess.
In previous post I did something wrong cause dot product of T and N must be zero and here its not
Your T looks wrong. What's dR/dt ? and what's |dR/dt| ?
I am using the parameter of your curve.
dR/dt=i+4j If I divide the length which its √17 I find dT/dt=i/√17+2/√17j I made a huge mistake I must be an idiot soort
Either you use the parameter t/\lambda,\theta or whatever you call it, or the arc-length s it doesn't matter...
\frac{d \vec{T}}{ds} will point to the same direction as \frac{d \vec{T}}{dt}. That can be seen by rewritting:
\frac{d \vec{T}}{ds} = \frac{d \vec{T}}{dt} \Big/ \frac{ds}{dt} so you are only getting a multiplicative factor of (ds/dt)^{-1} between the vector \frac{d \vec{T}}{ds} and \frac{d \vec{T}}{dt}. You don't care about that factor as long as you normalize them.
Likes RyanH42
RyanH42 said:
dR/dt=i+2j
this is wrong, what's the derivative \frac{d}{dt} (t^2+1)?
I made a huge mistake I must be an idiot so so soory
so?
Still you are taking the derivative wrong... \frac{d}{dt} (t^2+1) \ne 4
4t
RyanH42 said:
4t
close but no...
what ??
2t
how can I so dump ı have no idea.Actually I wite there 2j but it will be 2tj I missed the t and then I didnt read so I confused
Try practicing some derivatives...
No.I know derivatives really believe me.Just I am looking computer like 3 hours maybe 4 and my mind is melt
I will going to delete these one word posts.I can't do that
You don't have to help me If you have other works . I will check this question again .Thank you so much.Its your desicion to help me now
  • · Replies 25 ·
  • · Replies 17 ·
