Find Re(α+α^2+α^3+α^4+α^5): Solve Trig Series
  • Thread starter Thread starter utkarshakash
To find Re(α+α^2+α^3+α^4+α^5) where α = e^{i(8π/11)}, the discussion highlights that this expression can be treated as a geometric series. The real part can be expressed as the sum of cosines: cos(8π/11) + cos(16π/11) + ... + cos(40π/11). The approach involves simplifying the series using the formula for the sum of a geometric series, leading to a transformation of the expression. The final steps involve recognizing that α^6 can be rewritten, allowing for further simplification to reach the solution.
utkarshakash
If \large α = e^{i\frac{8∏}{11}}, then find Re(α+α^{2}+α^{3}+α^{4}+α^{5})
\large e^{i\frac{8∏}{11}}+e^{i\frac{16∏}{11}}...+e^{i\frac{40∏}{11}}
cos \frac{8∏}{11}+isin \frac{8∏}{11}...
Since I am interested only in real part so now I have to find the value of
cosθ+cos2θ...cos5θ
where θ= \frac{8∏}{11}
I think some trigonometry must be applied since it seems to me sum of a trigonometrical series.
cosθ+cos2θ...cos5θ
Is not
a geometric series?
hild
cosθ+cos2θ...cos5θ
You have found the real part; it is a sum of 5 terms. What is wrong with that answer?
RGV
RGV
Hey I have found the answer but not completely. I have to find the value of cosθ+cos2θ...
which I don't know how to solve
Well as people have already mentioned, the answer IS
\cos(8\pi/11)+\cos(16\pi/11)+...+\cos(40\pi/11)
but that's messy, and this question has been cleverly constructed so that there is a nice answer.
\alpha+\alpha^2+...+\alpha^5
=1+\alpha+\alpha^2+...+\alpha^5-1
=\frac{1-\alpha^6}{1-\alpha}-1
Now, notice that
\alpha^6=e^{48\pi i/11}=e^{4\pi i/11}=\left(e^{8\pi i/11}\right)^{1/2}=\alpha^{1/2}
So we can now turn the expression into
=\frac{1-\alpha^{1/2}}{1-\alpha}-1
=\frac{1-\alpha^{1/2}}{(1-\alpha^{1/2})(1+\alpha^{1/2})}-1
I'm sure you can finish it off from here :smile:
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
