Find the area of the shaded region
  • Thread starter Thread starter chwala
    Area
The discussion revolves around calculating the area of a shaded region formed by equilateral triangles. Participants explore various methods, including using ratios and properties of similar triangles, to determine the area accurately. One member corrects their earlier calculations, concluding that the area of the green parts is 7.0 square units after considering the areas of different triangles. There is also a debate about the necessity of squaring dimensions when comparing areas of similar triangles, emphasizing the relationship between linear and area scale factors. Ultimately, the conversation highlights the complexity of geometric calculations and the importance of understanding triangle properties.
chwala
Consider the diagram below, find the area of the shaded region
similarity-congruency
this is another question that i saw on the internet...
Likes Delta2
This is my attempt, in the first attempt i tried to see whether i could be able to find the shaded region by way of calculations.
In the second attempt, i tried to use ratio,...
i made a mistake in the area formula, the dimensions are not correct , let me re-do it...
the dimensions ought to be ##3.72cm## and not ##1.5cm## that is the dimensions for each equilateral triangle...
clearly this is not correct...i am missing something here...
Likes Lnewqban
AD should be 3.72 x 3.5.
Aaaaargh the last triangle...I will re do the working again...and at same time appreciate any alternative way of doing this.
Likes Lnewqban
I see 7 triangles, total area is 7 times 6 units of area: 42 units.
The diagonal line divides in half the shape formed by those 7 triangles: 21 units each big triangle.
Then, we remove the top triangle and investigate any symmetry among sides.
The top side measures 3 entire small-triangle sides.
In a symmetrical way, two of each truncated sides have the same dimension.
What could we do with that information?
Could we divide the area of the top big angle in two in order to obtain the value of the green area?
Interesting...I am an analytical person, these geometry shapes and checking for congruence or similarity I don't like it :cool: :biggrin::biggrin:lol
Likes docnet
Those are only two of the ways to reach the same conclusion. :smile:
If you also see 7 equilateral triangles, you would agree that the the diagonal line only devides the area of 6 of them.
Because in a symmetrical way, two of each truncated sides have the same dimension, we could imaginarily cut those shapes off from the big triangle formed by the 6 consecutive triangles and glue two matching sides together, obtaining three original triangles that way.
Therefore, the area of the green-colored parts is 6 units x 3 triangles = 18 units.
Likes chwala
Well, that's obviously wrong, or I read you wrong. Each of your two 'big triangles' is already 18 units. The green area encompasses a portion of that : looks like less than half.
(Not that I have anything positive to add).
I don't mean to judge. But surely you can take 5 min out of your day to understand the definition of similar triangles, there properties, and later similarity between different geometric objects? It will save you a lot of time this route, you learn more math, and spend less time using computations you don't need to do.
Likes chwala and Mark44
another member might have suggested this. but one could also set up a coordinate system and set up a handful of integrals.. not that anyone would WANT to do that lol
Likes Delta2
my other attempt...is the area of triangle ##AFT##=##4.396cm^2## or i am getting it wrong, are my angles correct?
Likes Lnewqban
noted, i will try boss...
Likes Lnewqban
It was wrong, indeed.
Thank you.
After calculating the areas of different triangles, and using ratios among similar triangles, I have this new result:
The area of the green-colored parts is 4.5 + 2.0 + 0.5 = 7.0 units square.
Likes chwala
Would you provide some hints on what you did? I cannot get anywhere without resorting to analytic geometry.
I used the similar triangles idea mentioned by @MidgetDwarf in post #12 above.
Please, see:
https://www.mathsisfun.com/geometry/triangles-similar.html
https://www.mathsisfun.com/algebra/trig-area-triangle-without-right-angle.html
Calculated the length of sides of any of the equilateral triangles.
##A=\sqrt{3}b^2/4=6##
##b=3.722~units##
Triangle AMN is similar to triangle ACD / Ratio = 4
Calculated length of CD
Calculated length of ##BC = b - CD##
Knowing that angle ABD is 60°, calculated area of triangle ABC, using
##A=(0.5)(AB)(BC)(sin~60)=4.5~units^2##
Triangles AGH and AKL are similar to triangle AMN.
Triangles EFG and IJK are similar to triangle ABC.
Repeated process for calculating areas of triangles EFG (##2.0~units^2##) and IJK (##0.5~units^2##).
Added individual areas for a total of ##7.0~units^2##.
Likes chwala and Frabjous
Thanks guys...
i saw this answer below on the internet; I am trying to follow it...I thought i should share it here,
what i do not understand is "why is he squaring'
##\frac{A_1}{A_2}##=##\frac{0.75^2}{0.5^2}## is it really necessary to square?i do not think so,
MY understanding is that ##(ASF)=(LSF)^2##
therefore, ##LSF ## of ##\frac{A_1}{A_2}##=0.75## ×##2##=\frac{3}{2}##
from here it follows that ##(ASF)=\frac{9}{4}##
I don't know what you mean by ASF and LSF.
The area of similar triangles is proportional to the square of the length of corresponding sides.
##(ASF)##= Area Scale Factor & ##LSF##= Linear Scale Factor...and of course,
##(VSF)##=Volume Scale Factor.
##(VSF)=(LSF)^3##
i was able now to use sine rule to find the areas;find attached...
what i was missing in this question was how to come up with the linear scale dimensions,
##0.75##, ##0.5## and ##0.25## for the 1st, 2nd and 3rd triangles respectively...
Likes Lnewqban
chwala said:
linear scale dimensions for the 1st, 2nd and 3rd triangles respectively...
But once you have those, it is obvious that the answer is
$$6 \times \frac{3}{4} \times (1 + (\frac{2}{3})^2 + (\frac{1}{3})^2 )$$ :biggrin:
Likes SammyS, chwala and jim mcnamara
  • Skeptical
Likes chwala and docnet
Does the spare triangle make any sense ?
Zgort said:
While it is true that the green area above the diagonal is equal to the white area below the diagonal, there is no reasoning given to show that the green area above the diagonal equals the white area above.
In other words, the is no reasoning given to show that half of each half is green and half of each half is white. In fact that's not true.
Likes chwala
