MHB Find the areas of segment in circle
  • Thread starter Thread starter Etrujillo
    Areas Circle
The discussion focuses on calculating the areas of sectors and triangles within circles. For a sector with a 120º angle, the area is calculated as 12π, and the area of the triangle formed is 9√3, leading to a shaded area of (12π) – (9√3). In a separate calculation for a 270º sector, the area is determined to be (3/4)81π, with the triangle area being 40.5, resulting in a combined area formula. The calculations are verified to be correct, confirming the methods used for finding the areas. Overall, the thread emphasizes accurate area calculations involving circular segments and triangles.
Etrujillo
So far i have.
14) area of sector is πr²/3 = 12π
length of chord. that triangle has two sides of 6 and angle of 120º
split the triangle in two right triangles with angle of 120/2 = 60 and hyp=6. other (longer) side is:
sin 60 = x/6
s = 6 sin 60 = 6(√3/2) = 3√3
third side is
s = 3 cos 60 = 3
area =(1/2)(3)(3√3) = 4.5√3, double for both triangles
subtract that from the sector to get (12π) – (9√3)
15) similar to above.
find the area of the 270º sector and add the area of the triangle
area of sector is (270/360)(π9²) or (3/4)81π
area of triangle is (1/2)81
Is this correct?
What can i do differently?
Mathematics news on Phys.org
Re: Find the area of the shared region.
14.) I would take the area of the circular sector, and subtract from it the area of the triangle to get the shaded area \(A\):
$$A=\frac{1}{2}r^2\theta-\frac{1}{2}r^2\sin(\theta)=\frac{r^2}{2}(\theta-\sin(\theta))$$
Next, we identify:
$$r=6\text{ cm}$$
$$\theta=\frac{2\pi}{3}$$
Hence:
$$A=\frac{(6\text{ cm})^2}{2}\left(\frac{2\pi}{3}-\sin\left(\frac{2\pi}{3}\right)\right)=3\left(4\pi-3\sqrt{3}\right)\text{ cm}^2\quad\checkmark$$
This is equivalent to the area you stated. :D
15.) I would find the sum of 3/4 of the area of the circle and the right isosceles triangle:
$$A=\frac{3}{4}\pi r^2+\frac{1}{2}r^2=\frac{r^2}{4}(3\pi+2)$$
We identify:
$$r=9\text{ in}$$
And so:
$$A=\frac{(9\text{ in})^2}{4}(3\pi+2)=\frac{81}{4}(3\pi+2)\text{ in}^2\quad\checkmark$$
This is equivalent to what you would get when you add the two areas you found.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
