Find the average force the carpet exerts
To find the average force exerted by the carpet on a falling brick, one must equate the work done by gravity to the work done by the carpet. The calculations yield an average force of 2 x 10^4 N for a 1 cm thick carpet and 4 x 10^3 N for a 5 cm foam pad. The discussion emphasizes the importance of knowing the stopping distance and the assumption of a constant force during the stopping process. For the space probe, a vector triangle approach is suggested to determine the mass of gas needed for a 30-degree course change, resulting in a required expulsion of 170 kg of gas. Overall, the conversation highlights the need for clear assumptions and boundary conditions in solving physics problems.
Soaring Crane
1. A 10 kg brick falls from a height of 2 m.
a. Suppose it falls unto a carpet, 1 cm thick. Assuming the force stopping it is constant, find the average force the carpet exerts on the brick. Answer: 2 x 10^4 N
b. Now if it falls onto a 5 cm foam rubber pad, what constant force is needed to bring it to rest? Answer: 4 x 10^3 N
I know the formula F*/\t =/\p. To get F, /\p//\t. But do these objects have any effects on the brick's displacement and the time interval? [In some of these problems, kinematic formulas are needed to find things that are not given besides what one seeks. I used v_f^2 = V_i^2 + 2a/\x to find the velocity (about 63 m/s) if there was no object on the ground.] Please tell me the steps to get the force.
2. A 7600-kg space probe is traveling through space at 120 m/s. Mission control determines that a change in course of 30 degrees is necessary and, by electric communication, instructs the probe to fire rockets perpendicular to its present direction of motion. If the escaping gas leaves the craft's rockets at an average speed of 3200 m/s, what mass of gas should be expelled? Answer: 170 kg
No one, not even the instructor, could figure out how to do this. 60-90-30 triangles, x and y components, and other momentum formulas were used but to no avail. How do you do this?
Thank you for any clues!
Well, the first one is not quite that easy. You can make some assumptions to build a crude model though.. You can make a guess of intrusion depth (like with the carpet) and assume a constant force (or some other a priori known force function). Every thing else is just setting boundary conditions..
The second one isn't very complicated. If the course change is only due to a perpenticular acceleration, you can simply apply the vector triangle to the velocity vectors. In that case is means, that v_y = sin(30°) v_x = .5 \cdot v_x. Does that get you where you want to get?
In your first problem the work done by gravity accelerating the block must be equal to the work done by the rug stopping it.
W_{Rug} = W_{Fall}
Remember W=fd
What is the force on the falling object?
What is the distance?
See if you can get to the solution with these hints.
You also have to assume (and it doesn't strike me as completely realistic) that the 1 cm. pad stops the brick IN EXACTLY 1 cm. and the 5 cm. pad stops the brick IN EXACTLY 5 cm. At least those are the only distance measurements given and you have to know the distance in which the object stops.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
