Find the current I in this electrical circuit
52 replies · 6K views · last reply
Would introducing Kirchhoff's voltage law make the problem too easy to solve?
Helly123 said:
View attachment 216507 For this matter, what everyone think, that BD is short circuit or not?
Not any more. Looks a lot differrent from the circuit in post #1 !
Here you simply draw the top right quarter circle as a horizontal line, erect the 6 ##\Omega## and see that it's parallel to the other 6 ##\Omega##
VDC= 6 V and Bob is the brother of your mother
:headbang: How do I manage to get this arithmetic wrong?! Yes we could just say the current through the 3 Ω resistor is ##\frac{9.6}{3}## = 3.2 A, and then the flow through the 9 Ω resistor is a third as much = (1 + 0.2/3) adding up to (4.2 + 0.2/3) = 4.26666... ≈ 4.27 A as you say. :blushing:
If you want to work in fractions, write 9.6 as 96/10, then work through the fractions. Thus:
##I = \frac{96}{10} \left( \frac{1}{3} + \frac{1}{9} \right)\;A##
Just a note - working in fractions, or just exact for that matter, is very nice in mathematics, but when solving basic physics problems like these, i see no benefit - it can even obscure the result which with a reduced fraction givs 64/15 A. This does not give an intuitive knowledge of the 'normal' kind of values for these problems.
Yeah I thought of that too.
I used to think that too. :oldbiggrin:
When you're comfortable with fractions, then I feel that the fraction result conveys the same information. Besides, you can always reduce the final result to a decimal version quickly enough.
Then I would highly recommend working symbolically, since this elucidates the relationships between the quantities in the configuration much clearer than does fractions. And this, too, will of course give the exact result if wished in the end.
Of course. Work symbolically as much as possible. In the end you'll still have an expression that needs to have values substituted and the math performed.
If the 3 ohm and 9 ohm were series, then we found the answer 0,8 A which is on the options... so the 3 ohm and 9 ohm not series but parallel?
You can see that they are en parallel, since both of the resistor terminals (of the 3 and 9 ohm resistors) share the same nodes.
If there's no option for giving around 4.27 A as an answer, there is a mistake in the options.
This one
Circuit schematic drawn as a circle: a 9,6 V battery on the left with current I shown on the top-left arc, a vertical wire from the top to the bottom with a 3 Ω resistor, a horizontal branch with a 6 Ω resistor on the right, and a 9 Ω resistor on the lower-right arc.
equals
Circuit schematic with terminals A at top and D at bottom, joined by a rectangular network: a resistor labelled 6 between nodes C and B, a resistor labelled 9 on the left branch and a resistor labelled 3 on the right branch.
equals
Circuit schematic with terminals A at top and D at bottom, nodes B and C joined by a horizontal wire, a resistor labelled 6 between C and B, resistor labelled 9 on the left branch and resistor labelled 3 on the right branch.
Which for some unspecified reason still shows a resistor between B and C in the post but not in the picture attached (below riight) ?:)
Obviously parallel , right ?
  • Circuit schematic drawn as a circle: a 9,6 V battery on the left with current I shown on the top-left arc, a vertical wire from the top to the bottom with a 3 Ω resistor, a horizontal branch with a 6 Ω resistor on the right, and a 9 Ω resistor on the lower-right arc.
  • Circuit schematic with terminals A at top and D at bottom, joined by a rectangular network: a resistor labelled 6 between nodes C and B, a resistor labelled 9 on the left branch and a resistor labelled 3 on the right branch.
  • Circuit schematic with terminals A at top and D at bottom, joined by two parallel branches; the upper nodes C and B are connected by a wire containing resistor 6, and the lower branches contain resistors 9 and 3.
  • Circuit schematic with terminals A at top and D at bottom, nodes B and C joined by a horizontal wire, a resistor labelled 6 between C and B, resistor labelled 9 on the left branch and resistor labelled 3 on the right branch.
  • Circuit schematic with terminals A at top and D at bottom, joined by two parallel branches; the left branch C has a resistor labelled 6 and the right branch B has a resistor labelled 3.
Yet another way to think about it.
Circuit diagram: a 9.6 V battery and 9 Ω and 3 Ω resistors on a loop, with a 6 Ω resistor shorted by a jumper wire; green arrows trace current paths and the loop is marked Split and Recombine.
If this handful of resistors and 9.6V battery were wired together it would be as though a jumper wire was connected across the 6Ω resistor.
What are the current path(s)?
A useful formula valid when two (and only two!) resistors are connected in parallel is Rt=(Ra*Rb)/(Ra+Rb).
  • Circuit diagram: a 9.6 V battery and 9 Ω and 3 Ω resistors on a loop, with a 6 Ω resistor shorted by a jumper wire; green arrows trace current paths and the loop is marked Split and Recombine.
Thanks guys. How about this?
Hand-drawn circuit diagram: a circular loop with a battery marked V = 9.6 V on the left, a 9 Ω resistor labelled C at the lower left, a 3 Ω resistor labelled B on the vertical wire, and a 6 Ω resistor labelled A on the horizontal wire, with current I shown on the upper left.
Is the 6o hm (A) short circuit (jumper wire)?
Circuit schematic with a 6V battery on the left and nodes A, B, C and D around a loop. Branches: 6 ohm between A and B, 6 ohm between B and D, 33 ohm between B and C, and 9 ohm between D and C.
Is the BD short circuit (jumper wire)?
  • Hand-drawn circuit diagram: a circular loop with a battery marked V = 9.6 V on the left, a 9 Ω resistor labelled C at the lower left, a 3 Ω resistor labelled B on the vertical wire, and a 6 Ω resistor labelled A on the horizontal wire, with current I shown on the upper left.
  • Circuit schematic with a 6V battery on the left and nodes A, B, C and D around a loop. Branches: 6 ohm between A and B, 6 ohm between B and D, 33 ohm between B and C, and 9 ohm between D and C.
Helly123 said:
Thanks guys. How about this? View attachment 216636
Can you draw a line from B to D without going through any components?
I suppose, i can not, it goes through AB. Isnt it?
Yes, so it is not shorted.
Let's ask this in another way. Is the voltage the same at both sides of the resistor?
Start at the positive battery terminal, and trace the circuit with your finger ...
Label the 6 ohm resistor "RA", one side of the resistor Z, and the other side Z'.
What is the voltage at Z?
9.6 volts.
And at Z'?
Also, 9.6 volts.
Hand-drawn circuit diagram: a 9.6 V battery in a loop with a 6 ohm resistor labelled A, a 3 ohm resistor labelled B and a 9 ohm resistor labelled C; a wire links the two sides of A, with voltage labels 9.6V and 0V and handwritten working in blue at top.
What does Ohm's law tell us? If the voltage is the same at both sides of the resistor (that is, voltage drop across the resistor is zero) then IRA=VRA/RA = 0 volts/6 ohms = 0 amps.
In effect, 6 ohm resistor RA is shorted by the "wire" between point Z and Z'.
In this drawing it's the same for connections between RA and RB. The only component with a voltage drop across it is the 9 ohm resistor RC.
Let's re-state the problem in yet another way.
RA is a 6 ohm resistor in parallel with a 0 ohm wire between point Z and Z'.
The general rule is that total resistance for two resistors in parallel is less than the smaller resistor. In this special case the smaller resistor is 0 ohms, and limits total resistance to 0 ohms.
  • Hand-drawn circuit diagram: a 9.6 V battery in a loop with a 6 ohm resistor labelled A, a 3 ohm resistor labelled B and a 9 ohm resistor labelled C; a wire links the two sides of A, with voltage labels 9.6V and 0V and handwritten working in blue at top.
So both A and B are short circuit, because the voltage stream in left side and right side are zero. I see.
