Find the current in the copper wire
The discussion focuses on calculating the current in a cylindrical shell of wire and the total current running through it, as well as determining the necessary potential difference. The initial attempts involved using area calculations and current density equations, but discrepancies arose between different students' answers, particularly for parts a and c. It was highlighted that integration is essential for accurately solving these problems, as relying solely on specific values can lead to incorrect results. After reworking the problem with integration, the correct answers were confirmed against the professor's solution. Understanding the integration process is crucial for mastering these types of physics problems.
Maiq
a) What is the current contained in the cylindrical shell of wire defined by R/2<r<R?
b) What is the total current running through the wire?
c) Given your answer to (b) what potential difference V must be applied between the ends of the wire?
J=ar
i=JA
A=\pir^{2}
R=ρL/A
For part a I found the area of the shell by subtracting the area of two circles with radius R and R/2. I then used that to find the current using equations i=JA and J=aR/2. For part b i did the same thing except used A=\pir^{2} for the area and J=aR. As for part c I found the resistance using the equation R=ρL/A with ρ=1.68x10^{-8} Ωm and the area the same as from part a. Then I used the answer for b with ohm's law to get the voltage. A classmate of mine did this problem differently and had different answers for part a and c (b was the same).
You realize you need to do some integrations here.
Well my classmate used integrations for his and like I said we had the same answer for b but for a our answers were different by a multiply of two. At the time I hadn't completed c so i couldn't compare those answers.
The important thing is not to get the right answer, it's to understand what to do. You need to integrate. If you got the right answer without integrating you just lucked out.
J=aR/2 gives the current density only at r=R/2, the least of the range of values for J. And it won't help to take the average of aR/2 and aR, because there's more area outside 3a/4 than inside 3a/4. This is why you need integration.
Alright I reworked part a using integration and checked the professors solution and I got it right. I see now why my answer was wrong thanks a lot for the help guys.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
