Find the distance the spring compresses
  • Thread starter Thread starter joemama69
    Spring
The discussion focuses on calculating the distance a spring compresses when a block slides into it while experiencing friction. Participants clarify the equations involved, particularly the energy balance between kinetic energy, spring potential energy, and work done against friction. There is a debate over the correct formulation of the quadratic equation and the appropriate handling of terms. The final answer is derived as Wnc = -m(v0)^2/2 (1 + k/bmg)^-1 after simplification. The conversation emphasizes careful algebraic manipulation and unit consistency throughout the problem-solving process.
joemama69
a block of mass m slides along ahrizontal table with speed v. At s = 0, it hits a spring with spting constat k and begins to experience a friction oforce. the coefficient of frictio is u, find the distance the spring compresses when it momentairly comes to rest.
i believe the friction part is umgs, is this correct
.5mv2 = .5ks2 + ugms
if this is correct, how do i get the s alone
It's a quadratic equation. Put it in standard form and solve it.
(That attachment doesn't seem to match the problem you described.)
s = -mg + or - (((mg)2 - 4(.5k)(mgh))/k).5
How did you get this from the equation you gave in your first post?
I suspect you're solving a different problem.
haha you i had a very similar one sorry about that
s = -umg + or minus (((umg)2 - 4(.5k)(-.5mv2))/k).5
That's almost right. (Redo it more carefully. Each term must have the same units.)
Also, only one of the + or - choices will make sense for this problem.
i redid and came up with the same
.5ks2 + umgs - .5mv2 = 0
a = .5k
b = umg
c = -.5mv2
-b - \sqrt{b^2-4ac}/2a
-umg - \sqrt{()^2 - 4(.5k)(-.5mv^2)}/2(.5k)
s = -umg - \sqrt{()^2 +kmv^2}/k
Careful with how you do the division by 2a. Everything is divided by 2a, not just the square root term. (Use parentheses to show this.)
And don't forget that it's + or -, not just -.
ok
i think it should be minus because the spring is being compressed, do you concure
No...
s = -umg + (((umg)2 - 4(.5k)(-.5mv2)).5/k
s = -umg + (((umg)2 + kmv2).5/k
You still haven't corrected the "division by 2a" problem from post #8.
= (-umg + ((umg)2 + kmv2).5)/k
the answer how ever is Wnc = -m(v0)^2/2 (1 + k/bmg)^-1 after simplifying
