Find the domain and rainge of this function (rational fn)
  • Thread starter Thread starter skyturnred
    Domain Function
skyturnred
Find domain and range of
f(x,y)=\frac{-3y}{x^{2}+y^{2}+1}
It's quite obvious the the domain is R^{2}, because there are no possible values of x or y that would make the denominator 0.
But as for the range, my prof said that the range is from -3/2 to 3/2.
I can't figure out why. In my opinion, the range should be R^{3}, shouldn't it? I mean, there is no value y that would make the function not make sense. Also, x isn't even in the numerator and since we already accounted for it in the denominator, there is also no value x that would make the function not make sense. So how isn't the range R^{3}?
Thanks in advance for the help.
The range isn't R^3 because the function f: R^2->R^1.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
