Find the energy levels of a spin s = 3/2 particle
pondzo
Find the energy levels of a spin ##s=\frac{3}{2}## particle whose Hamiltonian is given by:
##\hat{H}=\frac{a_1}{\hbar^2}(\hat{S}^2-\hat{S}_x^2-\hat{S}_y^2)-\frac{a_2}{\hbar}\hat{S}_z## where ##a_1## and ##a_2## are constants.
In the ##\hat{S}_z## basis ##\hat{S}_z## and ##\hat{S}^2## have the following matrix representations:
##\hat{S}_z=\frac{1}{2}\hbar\begin{bmatrix}1&&0\\0&&-1\end{bmatrix}##
##\hat{S}^2=\frac{3}{4}\hbar^2\begin{bmatrix}1&&0\\0&&1\end{bmatrix}##
We can rewrite the Hamiltonian as follows:
##\hat{H}=\frac{a_1}{\hbar^2}(2\hat{S}_z^2-\hat{S}^2)-\frac{a_2}{\hbar}\hat{S}_z##
Subbing the matrices in the "relevant equations" I get the following matrix representation for the Hamiltonian:
##\hat{H}=\frac{-1}{4}\begin{bmatrix}a_1+2a_2&&0\\0&&a_1-2a_2\end{bmatrix}##
I'm not sure where to go from here... since ##s=\frac{3}{2}## then ##m_s=-\frac{3}{2},-\frac{1}{2},\frac{1}{2},\frac{3}{2}##. Is the next step to work out the energy for each of these ##m_s## values?
So find: ##\langle\frac{3}{2},-\frac{3}{2}|\hat{H}|\frac{3}{2},-\frac{3}{2}\rangle,\langle\frac{3}{2},-\frac{1}{2}|\hat{H}|\frac{3}{2},-\frac{1}{2}\rangle,\langle\frac{3}{2},\frac{1}{2}|\hat{H}|\frac{3}{2},\frac{1}{2}\rangle,\langle\frac{3}{2},\frac{3}{2}|\hat{H}|\frac{3}{2},\frac{3}{2}\rangle,##? If so, I am a little confused as to the vector forms of some of those bras and kets.. Help is appreciated!
(Oh and by the way, my Lecturer made a mistake when he said a particle with spin s = 3/2, but he said to do the question regardless)
Those relations hold only for spin one-half particles. You don't need matrix representation actually, just use the fact that ##S^2 = S_x^2 + S_y^2 + S_z^2## to modify the first three terms contained in the bracket in the Hamiltonian.
Likes DrClaude
Hi Blue leaf, I realized this after I made the post and I think I have the correct answer now.
I just have one question: Is there a convention as to which order you evaluate the different ##m_j## values when computing the matrix elements? Is it ascending or descending?
It is usually descending, just like for a spin-1/2 particle:
$$\hat{S}_z=\frac{1}{2}\hbar\begin{bmatrix}1&0\\0&-1\end{bmatrix}$$
spin-3/2:
$$\hat{S}_z=\frac{1}{2}\hbar\begin{bmatrix}3&0&0&0\\0&1&0&0\\0&0&-1&0\\0&0&0&-3 \end{bmatrix}$$
But it is always better to specify which convention is used.
Likes pondzo
Ok thanks for the help!
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
