What is the general solution for y'' + 4y' + 4y = 5xe^(-2x)?
The general solution for the differential equation y'' + 4y' + 4y = 5xe^(-2x) is derived using the method of undetermined coefficients. The homogeneous solution is y_h = c1e^(-2x) + c2xe^(-2x), with roots from the characteristic equation (D+2)². The particular solution is confirmed to be yp = (5/6)x^3e^(-2x), correcting the initial miscalculation of (5/2)x^3e^(-2x). The final general solution combines both homogeneous and particular solutions.
  • Understanding of second-order linear differential equations
  • Familiarity with the method of undetermined coefficients
  • Knowledge of characteristic equations and their roots
  • Experience with exponential functions in differential equations
  • Study the method of undetermined coefficients in detail
  • Learn how to solve characteristic equations for higher-order linear differential equations
  • Explore variations of the exponential function in differential equations
  • Practice solving differential equations with non-homogeneous terms
Students and professionals in mathematics, particularly those studying differential equations, as well as educators looking for examples of solving second-order linear differential equations.
Squeezebox
Find the general solution
y'' + 4y' +4y = 5xe^(-2x)
I got (5/2)x^3*e^(-2x) as a particular solution. But I checked online at wolfram alpha and it says the particular solution is (5/6)x^3*e^(-2x). Using method of undetermined coefficients.
Solve the homogeneous part of y'' + 4y' +4y = 0. What are the roots of the characteristic equation?
The homogeneous part gave me
y=c1e-2x+c2xe-2x
from the root (D+2)2.
Multiplying by another (D+2) annihilated the 5xe-2x, resulting in a new solution
y=c1e-2x+c2xe-2x+c3x2e-2x
is that right?
Your right side is xe-2x, since -2 is seen twice in the homogeneous part, you must multiply it by x2.
Can you show your work on how you got the constant to be 5/2?
(D2+4D+4)(c3x2e-2x) = 5xe-2x
c3(4x2e-2x-8xe-2x+2e-2x+4(2xe-2x-2x2e-2x)+4x2e-2x) = 5xe-2x
Every thing but c3(2e-2x) reduces to zero
c3(2e-2x)=5xe-2x
c3=(5/2)x
c3(2e-2x)=5xe-2x
c3=(5/2)x
I thought you got yp=c3x3e-2x
yp=c3x2e-2x
yp=(5/2)x*x2e-2x
yp=(5/2)x3e-2x
