Find the imit of 2x + 1 - sqrt(4x^2 + 5) as x--> infinity
  • Thread starter Thread starter projection
    Infinity
projection
\lim_{x \rightarrow \infty}2x+1-\sqrt{4x^2+5}
i am wondering if this method that i used is correct. i get the correct answer but i ahaven't see it in the textbook or on the net. am i doing something that shouldn't be done?
using the limit laws, i take out 1.
\lim_{x \rightarrow \infty} 1 + \lim_{x \rightarrow \infty2x-\sqrt{4x^2+5}
then i rationalize.
\lim_{x \rightarrow \infty 1 + \lim_{x \rightarrow \infty} \frac{4x^2-4x^2-5}{2x+\sqrt{4x^2+5}}
1 + \lim_{x \rightarrow \infty}\frac{-5}{2x+x\sqrt{4+\frac{5}{x^2}}}
1 + \lim_{x \rightarrow \infty} \frac{\frac{-5}{x}}{\frac{2x}{x}+\frac{x}{x}\sqrt{4x+\frac{5}{x^2}}}
1 + \frac{0}{4}
1+0=1
i get the right answer when i do it for \lim_{x \rightarrow \infty\sqrt{9x^4-3x^2+1} - 3x^2+5 and these the only two i tried. is this method just lucky for these two or can i keep using it?
also. i seem to be getting the right limit of 1 when x approches postive infinity for \lim_{x \rightarrow \infty\sqrt{9x^2+6x-5} - 3x but i get -1 when approches negative infinity and mathematica keeps telling me its +infinity. can someone do provide me with a soloution?
I have no idea what your problem says, please fix your latex!
infinity = \infty
lim as x approaches a = \lim_{x \rightarrow a}
better?
try pulling the x^2 out of the square root and then so how that affects the terms inside the square root as x goes to inf.
i tried to solve it, but i keep on ending up with a zero at the bottom. does this mean that what i did is wrong or the limit is infinity whenever you end up with a zero in the denominator?
THE INFINTY IS NEGATIVE. sorry i don't know to syntex of a negative.
\lim_{x \rightarrow- \infty\sqrt{9x^2+6x-5} - 3x
\lim_{x \rightarrow- \infty\sqrt{9x^2+6x-5} - 3x . \frac{\sqrt{9x^2+6x-5}+3x}{\sqrt{9x^2+6x-5}+3x}
\lim_{x \rightarrow- \infty \frac{6x-5}{\sqrt{9x^2+6x-5}+3x}
\lim_{x \rightarrow- \infty \frac{6x-5}{|x|\sqrt{9+\frac{6}{x}-\frac{6}{x^2}}+3x}
\lim_{x \rightarrow- \infty \frac{6-\frac{5}{x}}{\frac{|x|}{x}\sqrt{9+\frac{6}{x}-\frac{6}{x^2}}+\frac{3x}{x}}
\frac{6}{-1\sqrt{9}+3}
\frac{6}{0}
so does this mean the what i did is wrong, or does this indicate the limit is infinity like mathematica keep telling me and what i did is the correct steps?
Why is |x| / x = -1 if x goes to + infinity? What is |x| if x becomes very large?
And my Mathematica doesn't tell me it's infinity.
^^^ oh i forgot to do it there but its going to negative infinity.
i will fix it.
i am getting the correct answer for all positive inf questions. just neg ones i am not getting.
can someone show me the proper soloution. i tried to find some explanation on the web but no help. i keep getting a zero in the denominator when i use this method.
