Find the length of a side of a cube
  • Thread starter Thread starter poohbear1986
    Cube Length
To find the length of a side of a cube given its volume of 800 cm³, use the formula V = s³. To isolate s, take the cube root of the volume, resulting in s = V^(1/3). For 800 cm³, calculate s = 800^(1/3), which approximates to 9.283 when rounded to three decimal places. The discussion clarified the steps to manipulate the equation and correctly apply the cube root. Understanding these concepts is essential for solving similar problems in geometry.
poohbear1986
trying to figure this out, but am confused on the steps please help thank you
The volume of a cube is given by V = s3, where s is the length of a side. Find the length of a side of a cube if the volume is 800 cm3. Round the answer to three decimal places.
You already know the volume that you want (800cm^3). And you have an equation for the volume and the unknown(the unknown being s). Can you show me the equation you have for "s" in terms of "V" ?
i was no given one, i think my teacher is a moron
It looks like you were given one. You said in your opening post that the volume "V" is equal to 3 times "s," so you have V = 3s. Can you tell me what s equals in terms of "V"?
It's the volume of a cube with side length s, I believe that s3 was meant to be s3.
Ah, you're correct. My mistake.
Well, for poohbears sake, I'll give an example of what your teacher is looking for.
If I havey = x^{4} , then I can put x in terms of y by multiplying both x and y to the \frac{1}{4} power:
y^{\frac{1}{4}} = x^{4*\frac{1}{4}}= x
Now I have x in terms of y. Just multiply both sides of your equation by a similar power to get s in terms of the volume. Sorry for any confusion.
can you use numbers its easier to see what you mean
thanks
thanks
Sure, we can do that. If I say 16 = x^{4}, then I want to multiply both sides of the equation by the one-fourth power:
16^{\frac{1}{4}} = x^{4*\frac{1}{4}}= x
Then just plug 16 to the 1/4 power into your calculator to find that x = 2.
still not understanding both sides of my equation are gooing to have cubed numbers
You have V = s^{3}. What power must you multiply both sides by to get s in terms of V? If you multiplys^{3} by a certain power, you'll get s all by itself. Follow the reasoning in the example above.
so if i multiply both sides by 1/3 i should get what I'm looking for
Not by 1/3, but to the 1/3 power. Notice in the example above that we're multiplying both sides by a power. Here's one more to try:
If I have 81 = x^{4} , I want to multiply each side by the 1/4 power to find x:
81^{\frac{1}{4}} = x^{4*\frac{1}{4}} = x
When you plug in 81 to the one-fourth power, that is 81^(1/4), you should find that x = 3.Try the examples above on your calculator so you're comforable with the concept.
thanks a lot i finally understand what I'm looking at, i appreciate the help
No problem :) Keep up the good work.
