Find the Limit: Finf simple limit Find \lim_{x \rightarrow 1}
  • Thread starter Thread starter John O' Meara
    Limit
To find the limit \lim_{x \rightarrow 1} \frac{\sin(\pi x)}{x-1}, the discussion highlights the difficulty in direct substitution leading to indeterminate forms. A suggested approach involves using the substitution t = x - 1, transforming the limit into \frac{-\sin(\pi t)}{t}. As t approaches 0, the limit can be evaluated using the known limit of \frac{\sin(u)}{u} as u approaches 0. This method provides a clearer path to finding the limit without needing advanced rules like L'Hôpital's. The conversation emphasizes understanding basic limit properties to resolve the problem effectively.
John O' Meara
Find \lim_{x \rightarrow 1} \frac{\sin(\pi x)}{x-1}. I have tried to find this limit by letting t= \pi x t= x-1, etc. All I get is 1/0 or \pi/0 or etc., but not the answer the graph of the function suggests. I cannot find the substitution for x that will work. Is there some rule that I can use to find a suitable substitution for x or expression for t. I am doing this for my own interest. Can anyone point me along the correct line of reasoning that will allow me find the expression for t= ? . Thank you.
Mathematics news on Phys.org
Have you tried l'hopital's rule?
No, the book does not mention L'Hopital's rule until page 470, I am on page 135, so I don't think it means us to use that rule.
\frac{sin(\pi x)}{x-1} = \frac{sin(\pi(x-1) + \pi)}{x-1} = \frac{sin(\pi(x-1))cos\pi + sin(\pi)cos(\pi(x-1))}{x-1} = \frac{-sin(\pi(x-1))}{x-1}.
Let t = x - 1. Then \frac{-sin(\pi(x-1))}{x-1} = \frac{-sin(\pi t)}{t} = \frac{-\pi sin(\pi t)}{\pi t}.
As x goes to 1, t = x - 1 goes to 0. You know the limit of sin(u)/u as u goes to 0 right? Now use that.
Thanks very much.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
