Find the limit of this function
In summary, the limit of a sequence is the point at which the sequence reaches its largest value. For continuous functions, the limit is the point at which the function reaches its smallest value.
racer
39
Hey there
Find the lim of F(X) as X approaches zero
F(X) = 0/X ( Zero over X )
Thanks.
Well its a constant function equal to 0 for all values of x not equal to zero. So we can see the limit is equal to 0.
You could also use l'Hopital and get the same answer as Gib_Z provided.
Yeah it is zero but I want the lim without L'Hopital rule, I want the solution using Algebra.
Find the Lim of 0/X as X approaches zero.
0/X = X-X/X = X/X - X/X = 1-1 = 0
alternatively you can say that if y is a member of the the Reals then 0*y=0 set y=1/x. While not wrong, your solution simply overcomplicates things.
no matter what x is, the answer will always be 0. unless x = 0, then it is undefined. so you can say it is just approaching 0
f(x) approaches L as x goes to a if and only if f(x_n) approaches L for any sequence of numbers x_n approaching a.
Let x_n be any sequence of numbers approaching 0. What is 0/x_n? What is the limit of that sequence.
I don't know anything about Sequence limits.
But you ask of the limit of continuous functions?
Do you know the definition of a limit? If so it is obviously zero.
Related to Find the limit of this function
What does it mean to "find the limit of a function"?
Finding the limit of a function is the process of determining the value that a function approaches as its input approaches a specific value. This value is often referred to as the "limit point" or "limit value".
Why is finding the limit of a function important?
Finding the limit of a function can help us understand the behavior of the function at certain points and can also help us determine if a function is continuous at a specific point.
What are the different ways to find the limit of a function?
There are several methods for finding the limit of a function, including direct substitution, factoring, and using algebraic manipulations. Additionally, we can use graphs or tables to approximate the limit of a function.
What are some common mistakes when finding the limit of a function?
One common mistake is assuming that a function is continuous at a specific point without properly evaluating the limit. Another mistake is using incorrect algebraic manipulations or not considering the possibility of a one-sided limit.
Are there any real-world applications of finding the limit of a function?
Yes, finding the limit of a function has real-world applications in fields such as physics, engineering, and economics. For example, in physics, the limit can be used to determine the speed of an object at a specific time, and in economics, it can be used to model the growth of a company or the demand for a product.
  • Calculus
  • Calculus
  • Calculus
  • Calculus
  • Calculus
  • Calculus
