Find the linear portion of a curve
  • Thread starter Thread starter RandomGuy88
    Curve Linear
To find the slope of the linear portion of a curve from experimental data, one can utilize curve fitting techniques to isolate the linear segment automatically. Manual removal of non-linear sections is an option, but automating this process is preferable. Suggestions include using robust regression methods to minimize the influence of outliers. Differentiation of the fitted curve can also help identify where the slope is constant. The discussion highlights the challenges of replicating human intuition in data analysis through programming.
RandomGuy88
Hi,
So I have a set of experimental data and I would like to find the slope of the linear portion of the data. For example, say I have set of points, the first few points are not linear, then there is a chunk of data in the middle that is linear, and then the last several points are very non-linear. I would like to find the slope of this linear portion in the middle but the location and length of the linear portion will be different for each experiment. I could easily do this by just manually removing the non-linear portions of the curve but I would like for the computer to be able to do this automatically. Does anyone have any suggestions on the best way to do this?
Thanks
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
