Find the magnitude of the electric field at point P
The discussion focuses on calculating the electric field at point P due to two identical charged spheres positioned at the vertices of an equilateral triangle. The initial calculations incorrectly used the distance to the midpoint instead of the correct distance to point P, which is 3m. After correcting this, the resultant electric field components were recalculated, leading to a net electric field of 5196 N/C. The final answer choice is confirmed to be B. The importance of accurately identifying the distance in electric field calculations is emphasized.
paulimerci
Question posted below.
E = kq/r^2
There are two identical spheres with the same charge that are the vertices of an equilateral triangle. ##+3 \mu C## will exert an outward electric field, which is drawn in the FBD below (see the attached pic), Since the horizontal force components (1x and 2x) are equal and opposite at point P, we can cancel those two vectors, and the remaining y component vectors will give the resultant magnitude of the electric field at point P.
$$ E = \frac {kq}{r^2}$$
$$ E_{1y} = \frac {8.99 \times 10^9 \times 3 \times 10^-6 sin 60} {6.76}$$
$$ E_{1y} = 3455 N/C$$
$$E_{2y} = \frac {8.99 \times 10^9 \times 3 \times 10^-6 sin 60} {6.76}$$
$$ E_{2y} = 3455 N/C$$
$$ E _{net} = 6910 N/C$$
I'm not sure where I made a mistake because none of the answers match my answer. Can anyone point out where my mistake is?
What does r represent in your relevant equation? Think.
r is the distance between the charge and the reference point (P).
I see where I did a mistake I took the wrong distance (between P and the midpoint between two charges). r=3m, Is ##E_{1y} + E_{2y} = 2598+2598 = 5196 N/C##. So the answer choice is B?
Looks right.
haruspex said:
Looks right.
Thank you!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
