Find the maximal distance of flying
  • Thread starter Thread starter annalian
    Flying Speed
The problem involves calculating the maximal distance a bullet flies when launched at an initial speed of 200 m/s and an angle of π/3 radians. The formula used for this calculation is L = v0^2 * sin(2a) / g. Substituting the values, the solution yields a maximum distance of approximately 3464.1 meters. The calculations confirm the accuracy of the result based on the provided equations. The discussion effectively resolves the problem using standard physics principles.
annalian
A bullet flies with initial speed v0=200m/S under the angle pi/3rad. Find the maximal distance of flying
L=v0^2*sin2a/g
L=40000*sqrt(3)/2/10=3464.1 m
L=v0^2*sin2a/g
Right.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
