Find the scalar, vector, and parametric equations of a plane
The discussion focuses on finding the scalar, vector, and parametric equations of a plane with a given normal vector and a point it passes through. The scalar equation derived is correct, resulting in 3x - 4y + 6z + 11 = 0. However, initial attempts at the vector and parametric equations contained errors, particularly in point calculations. After corrections, the final parametric equations are confirmed as x = 9 - 9s - 7t, y = 2 + (3/4)s + (15/4)t, and z = -5 + 5s + 6t. The verification process for the scalar equation shows that the point P(9, 2, -5) lies on the plane, confirming the solution's accuracy.
Physics345
that has a normal vector n→=(3,−4,6) and passes through the point P(9, 2, –5).
Ax+By+Cz+D=0
(x,y,z)=(x0,y0,z0)+s(a1,a2,a3)+t(b1,b2,b3)
x=x0+sa1+tb1
y=y0+sa2+tb2
z=z0+sa3+tb3
Scalar Equation:
3x-4y+6z+D=0
3(9)-4(2)+6(-5)+D=0
D=11
3x- 4y +6z+11=0
Vector Equation:
4y=3x+6z+11
y=3/4 x+6/4 z+11
y=3/4 x+3/2 z+11
P(9,2,-5)
Let x=0 and z=0
y=11
Q(0,11,0)
let x=2 and z=1
y=3/4(2)+3/2(1)+11
y=14
R(2,14,1)
(PQ) ⃗ =Q-P
(PQ) ⃗ =(0,11,0)-(9,2,-5)=(-9,9,5)
(PR) ⃗ =R-P
(PR) ⃗ =(2,14,1)-(9,2,-5)=(-7,12,6)
(x,y,z)=(9,2,-5)+s(-9,9,5)+t(-7,12,6)
Parametric Equations:
x=9-9s-7t
y=2+9s+12t
z=-5+5s+6t
Did I do this correctly? And is there anyway to confirm my answers through math? Thanks in advance =)
Ax+By+Cz+D=0
x=x0+sa1+tb1
y=y0+sa2+tb2
z=z0+sa3+tb3
Scalar Equation: is OK.
Vector Equation:
4y=3x+6z+11
y=3/4 x+6/4 z+11
You did not divide 11 by 4 .
y=3/4 x+3/2 z+11
P(9,2,-5)
Let x=0 and z=0
y=11
Q(0,11,0)
That point is not in the plane.
let x=2 and z=1
y=3/4(2)+3/2(1)+11
y=14
R(2,14,1)
(PQ) ⃗ =Q-P
(PR) ⃗ =R-P
x=9-9s-7t
y=2+9s+12t
z=-5+5s+6t
The parametric version is also incorrect.
Likes Physics345
SammyS said:
Scalar Equation: is OK.You did not divide 11 by 4 .That point is not in the plane.
Which point are you referring to from PQR? Is it because of the division mistake?
I am referring to the point Q at (0, 11, 0) .
That does appear to me to be the result of your division mistake.
Okay according, to your comments I made some adjustments, how are you able to tell by the way?
y=3/4 x+3/2 z+11/4
P(9,2,-5)
Let x=0 and z=0
y=11/4
Q(0,11/4,0)
let x=2 and z=1
y=3/4(2)+3/2(1)+11/4
y=23/4
R(2,23/4,1)
(PQ) ⃗=Q-P
(PQ) ⃗=(0,11/4,0)-(9,2,-5)=(-9, 3/4,5)
(PR) ⃗=R-P
(PR) ⃗=(2,23/4,1)-(9,2,-5)=(-7,15/4,6)
(x,y,z)=(9,2,-5)+s(-9, 3/4,5) +t(-7,15/4,6)
x=9-9s-7t
y=2+3/4 s+15/4 t
z=-5+5s+6t
What is the thing that you are asking about? I made four different statements in my post #2 of this thread.
That the points were wrong. Also is it right now?
x=9-9s-7t
y=2+3/4 s+15/4 t
z=-5+5s+6t
Your results are now correct.
As far as checking your results:
I knew that your scalar equation for the plane was correct, by verifying the steps you took.
Using the scalar equation, it's easy to check that a given point is in the plane. Plug-in x, y, and z .
Likes Physics345
P(9,2,-5)
3x- 4y +6z+11=0
3(9)-4(2)+6(-5)+11=0
=0
How did it verify? because it equals zero?
Physics345 said:
P(9,2,-5)
3x- 4y +6z+11=0
=0
Yes. Plugging into the equation gave a "true" statement.
Likes Physics345
Thank you, I understand now. Your help was very much appreciated.
Likes SammyS
