Find the trajectory of a boat that moves in a river
The discussion focuses on determining the trajectory of a boat moving across a river with a constant velocity, considering both the river's flow and the boat's speed. The problem presents a scenario where the boat starts from point P and aims for point Q directly across the river, with the river's width denoted as D. Participants express confusion about how to approach the problem, particularly in vector representation and the relationship between the boat's velocity and the river's current. Clarifications are made regarding the boat's movement relative to the river and the shore, emphasizing the need to analyze the velocities as vectors. The trajectory can be expressed mathematically, but understanding the vector dynamics is crucial for solving the problem accurately.
david22
A boat part from the point P of the bank of a river, with width D, and that flows with a constant velocity VR, and moves with a constant velocity VB, directed towars a point Q, located on the other side of the river directly in front of P. If r is the instantaneous distance of the boat respect to Q and θ is the instantaneous angle between r and PQ, show that the trajectory of the boat is determined by:
r=Dsecθ/(secθ+tanθ)VB/VR
I am completely lost in this problem; I to put the instantaneous distance of the boat r as a vector and a took Q as my origin r = cos(90-θ)i+sen(90-θ)j but then i don't know what else to do; I would appreciate your help a lot
Have you copied the problem text correctly? "A boat part from the point P of the bank of a river, with width D, and that flows with a constant velocity VR, and moves with a constant velocity VB, directed towars a point Q, located on the other side of the river directly in front of P." If the boat moves with constant velocity it never reaches point Q. Was not it constant speed with respect to the river?
You are right, treat the position and velocity of the boat as vectors. The velocity of the boat with respect to the river points towards Q. What is the velocity of the boat with respect to the shore?
ehild
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
10K
  • · Replies 16 ·
  • · Replies 22 ·
