Find the zeroes of r. What to do when it is a multiple of theta?
  • Thread starter Thread starter Tyrion101
    Multiple Theta
To find the zeros of the equation 5 + 10cos(2θ) = 0, first isolate cos(2θ) to get cos(2θ) = -1/2. The next step involves determining the angles where the cosine function equals -1/2, which occurs at 2θ = 2π/3 + 2kπ and 2θ = 4π/3 + 2kπ, where k is any integer. After finding 2θ, divide by 2 to solve for θ. Consulting a trigonometry textbook can provide additional examples and methods for solving such equations involving angle multiples.
Tyrion101
I understand what to do when theta is by itself such as r=5+10cos(theta) but what if you have the same equation, and it is (2theta) I am on taptalk by the way.
Mathematics news on Phys.org
What have you tried?
In essence, you're trying to solve the equation ##5 + 10\cos(2\theta) = 0##.
Well if it were without the 2*theta I'd set it equal to 0, like you did, and solve for cos(theta). Well anyway without the 2 you turn the equation into cos=-1/2, would I just multiply -1/2 by 2? Or would I add 2pi or something?
Solve for 2*theta. Solve for theta from that.
You took a trig class, right? Do you still have your textbook? If so, there should be numerous examples of solving trig equations, including ones that involve the sine or cosine (or other trig function) of angle multiples.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
