Find time given initial velocity, distance and acceleration.
To determine the time it takes for the anvil to hit the ground after being dropped from a height of 50m, the quadratic equation was used, yielding a positive solution of approximately 2.33 seconds. The velocity of the anvil just before impact was calculated using the formula V = Vo + AT, resulting in a value of 32.9 m/s. The negative sign in the final velocity indicates the direction of the fall, which is downward. The discussion highlights the importance of correctly interpreting the signs in physics equations. Understanding these concepts is crucial for accurately solving similar problems.
physicN00Bz
Coyote falling down with a parachute holding an anvil at 10m/s. At 50m he drops the anvil.
A) How long does it take for the anvil to hit the ground?
B) what is the velocity of the anvil right before it hits the ground?
X= Xo + V0T+1/2A(T^2)
g= 9.8 m/s^2
50m = 10m/sT + 4.9m/s^2T^2
i use the quadratic equation and got t= 1.14 and -2.143
however i know this is wrong since i can not get a negative second and it seen like the "s" cancel out and you got T = a number without second.
also i know the answer is 2.33 s for (A) but want to know how to get that answer.
Seems like you've done everything correctly except solving the quadratic. I get 2.333 and -4.37381 for my solutions. Or at least my calculator does...
yeah i actually re did the quadratic i also got 2.33 and -4.373
ok for
i use V = Vo + AT and got V= 10m/s + 9.8 m/s^2(2.33s) got V =32.9 m/s
However the answer is in negative (as in -32.9 m/s) what did i do wrong to miss the negative sign?
