Find x and y values that satisfy the given conditions
  • Context: MHB
  • Thread starter Thread starter Albert1
    Value
The discussion focuses on finding three-digit numbers \( x \) such that \( y = x^2 \) and the last three digits of \( y \) equal \( x \). The solutions identified are \( x = 376 \) and \( x = 625 \), leading to \( y = 141376 \) and \( y = 390625 \) respectively. The mathematical approach involves modular arithmetic, specifically \( x^2 \equiv x \pmod{1000} \), and utilizes a Python 3 script to efficiently enumerate potential solutions through recursion.
  • Understanding of modular arithmetic, specifically \( x^2 \equiv x \pmod{m} \)
  • Familiarity with Python 3 programming, particularly recursion
  • Knowledge of number theory concepts such as coprimality and prime factorization
  • Basic understanding of algorithm efficiency and complexity analysis
  • Study modular arithmetic applications in number theory
  • Learn about Python recursion techniques for problem-solving
  • Explore efficient algorithms for finding modular solutions
  • Investigate the implications of coprimality in number theory
Mathematicians, computer scientists, and programmers interested in number theory, algorithm optimization, and modular arithmetic applications.
Albert1
x=abc is a three digits number
y=$x^2$
the last 3 digits of y is also equal to abc
that is y=?abc
please find x and y
Mathematics news on Phys.org
Re: find the value of x and y
$$x^2 \equiv x \pmod{1000} \tag{1}$$
Clearly for $x$ coprime to $1000$, the only solutions are the trivial $x = 0$ and $x = 1$, so all nontrivial solutions for $x$ must be divisible by either $2$ or $5$, or both. This leaves us with about $600$ possible candidates. Now it should be clear that if a solution works for $1000$, it will also work for $100$, and for $10$. Let's try and find the solutions for $10$:​
$$x^2 \equiv x \pmod{10} \tag{2}$$
We have $5$ potential solutions here, namely $2, 4, 5, 6, 8$ (modulo $10$). Let's check each of them manually, some calculations show that only $5$ and $6$ work. So the solutions must have either $5$ or $6$ as a last digit. Let's now extend our search to $100$, armed with this information (which reduces the set of possible solutions considerably):​
$$x^2 \equiv x \pmod{100} \tag{3}$$
We know from the previous step that the potential solutions are $5, 6, 15, 16, \cdots$. A short exhaustive search tells us that only $25$ and $76$ work. Finally, we have narrowed down the search enough to look for the real solutions:​
$$x^2 \equiv x \pmod{1000} \tag{4}$$
The only possible solutions are $25, 76, 125, 176, \cdots$. Again, trying those 20 potential solutions shows that only $376$ and $625$ work. Therefore, the solutions are $x \in \{ 0, \, 1, \, 376, \, 625 \}$. QED.
This might look like a non-answer given the amount of trial and error involved, but consider that we've only had to try $45$ potential candidates instead of the original $600$, and the cost of this algorithm is asymptotically logarithmic, for instance, finding the solutions with $m = 100000$ would only take $85$ trials, quite efficient.​
Here's an Python 3 script implementing the algorithm outlined above, using recursion, for powers of $10$:
Code:
# Work count
work = 0
def Verify(x, m):
    global work
    work += 1
    return pow(x, 2, 10**m) == x
def Solve(m):
    # Solutions
    found = []
    if m == 1:
        for x in [2, 4, 5, 6, 8]: # Precomputed
            if Verify(x, m):
                found.append(x)
        return found
    possible = Solve(m - 1)
    for p in possible:
        for x in range(p, 10**m, 10**(m - 1)):
            if Verify(x, m):
                found.append(x)
    return found
def Enumerate(m):
    global work
    work = 0
    found = Solve(m)
    # Add trivial solutions
    found.append(0)
    found.append(1)
    found.sort()
    print("Solutions are {" + ', '.join(str(x) for x in found) + "}.")
    print("Checked " + str(work) + " candidates.")
Which gives us (spaces added for readability):
Code:
>>> Enumerate(1) # For 10
Solutions are {0, 1, 5, 6}.
Checked 5 candidates.
>>> Enumerate(2) # For 100
Solutions are {0, 1, 25, 76}.
Checked 25 candidates.
>>> Enumerate(3) # For 1000
Solutions are {0, 1, 376, 625}.
Checked 45 candidates.
>>> Enumerate(5) # For 100000
Solutions are {0, 1, 9376, 90625}.
Checked 85 candidates.
>>> Enumerate(8) # For 100000000
Solutions are {0, 1, 12890625, 87109376}.
Checked 145 candidates.
Interestingly, there are only two nontrivial solutions for any power of $10$, and these two solutions add up to $-1$ modulo said power, suggesting that there might exist an analytic solution to this problem, though the prime factorisations of the solutions display no obvious pattern apart from a large number of powers of $2$ and $5$.
So if a better way to do this exists, I'd be interested to see it. It is worth noting that the condition $x^2 \equiv x \pmod{m}$ implies $x^n \equiv x \pmod{m}$ for all $n > 0$, but I could not find how to use this property, sadly.​
y=$x^2$
that is y=?abc
please find x and y
y-x =$x^2-x =x(x-1)$ must be a multiple of 1000
for 1000=$2^3 \times 5^3 =8\times 125$
further more x and (x-1) are coprime
if x is a multiple of 125 then x-1 must be a multiple of 8---------(1)
if x is a multiple of 8 then x-1 must be a multiple of 125---------(2)
so the possible solutions meet restriction of (1) and (2) will be x=376 , and x=625
y=141376=$376^2$ , and 390625=$625^2$
