Find y'' by implicit differentiation
bobraymund
Find y'' by implicit differentiation.
I get to this point in the problem, which is I solved for y'. But then when I attempt to take y'', in other words take the derivative of my answer for y', I don't get the answer that is in the back of the book.
Many thanks in advance,
Bob
You went astray in the 2nd line and all following lines. The second line should be
18x + 2y dy/dx = 0 and your last line should be dy/dx = -9x/y. Now take the derivative again, keeping in mind that you need to use the quotient rule and the chain rule, in that order.
so y*y'=-9x
so take d/dx of both sides
for d/dx(y*y') use the product rule .
Bob, your last equation can be rewritten as; y'=-9xy^-1---->from here here you may get the y" by product rule and arrive at having y"=9/y^2(x-y)--->is this what you got in your book?
You can rewrite your last equation to: yy'=-9x---> from here try implicit differentiation.
You'll arrive at having: yy"+y'y'=-9; next, substitute the value of y'=-9x/y (previously derived); You'll arrive at having: y"=-9/y^3(9x^2+y^2).
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
