Finding a limit without L'Hospital's Rule
  • Thread starter Thread starter mr.tea
    Limit
mr.tea
Hi,
I have been trying to find the limit of the following expression in order to determine the Big-o(in particular, the order of decaying to zero)
\lim_{x\rightarrow 0} \frac {\cos (x) -1 +\frac {x}{2} }{x^4}
Is there another "reasonable" way to solve it?
Thank you,
Thomas
I have tried to factorize x^2 in the numerator and denominator, and yield nothing(well, yield that the limit goes to infinity,). tried to replace cosx with sqrt(1-sin^2 x) and multiply with the conjugate but nothing.
This limit doesn't exist, as can be seen from the Maclaurin series of ##\cos##. Maybe you wanted ##\frac{x^2}{2}## instead of ##\frac{x}{2}##?
Likes mr.tea
What's a simple equivalent in 0 of ##\cos(x)## ?
Likes mr.tea
mr.tea said:
Hi,
\lim_{x\rightarrow 0} \frac {\cos (x) -1 +\frac {x}{2} }{x^4}Is there another "reasonable" way to solve it?
Thank you,
Thomas
It would be a much more interesting problem if that was x2/2 in the numerator.
Are you sure that shouldn't be :
##\displaystyle \ \lim_{x\to 0} \frac {\cos (x) -1 +\displaystyle \frac {x^2}{2} }{x^4} \ ##​
Likes mr.tea
oh! sorry! it is like that!
it is so embarrassing!
The Equation is with x^2/2...
Sorry about that.
Thomas
Sorry about that.
Thomas
The quickest way to get a solution is to use the Taylor expansion for cosine.
Likes mr.tea
Thank you for your answer.
We have not learned Taylor expansion yet. So, is there a reasonable way to solve it with simple algebraic steps?
(well, this question is not so important if there is no reasonable way to solve it, so don't feel obliged to give a full solution. Idea will be enough. I have solved it already by L'H., but I am probably a masochist :headbang: )
(well, this question is not so important if there are no reasonable way to solve it . I have solved it already by L'H., but I am probably a masochist :headbang: )
Write the numerator as ##\displaystyle \ \cos (x) +\left(\displaystyle \frac {x^2}{2} -1\right) \ ##.
Then multiply the numerator & denominator by ##\displaystyle \ \cos (x) -\left(\displaystyle \frac {x^2}{2} -1\right) \,,\ ## to get a difference of squares in the numerator.
Do some simplifying & see what pops out.
