Finding acceleration of an object (with friction)
A 1,300-N crate is being pulled across a level floor at a constant speed by a force of 310 N at an angle of 20° above the horizontal, with a coefficient of kinetic friction of 0.207. The user attempted to calculate the acceleration but arrived at 0.0340 m/s², while the expected answer is 0.331 m/s². Key points of confusion include the correct application of forces in the y-direction and the relationship between weight and mass. It was clarified that the weight of the crate (1,300 N) can be used to find mass, which is essential for calculating acceleration using F=ma. The discussion emphasizes the importance of accurately accounting for all forces acting on the crate.
Joe26
A 1,300-N crate is being pulled across a level floor at a constant speed by a force of 310 N at an angle of 20.0° above the horizontal. If coefficient of kinetic friction is 0.207, find the acceleration of the crate.
Fk= (uk)(N)
F=ma
Fx= 310cos20
Fy= 310sin20
N=1300-310sin20
Fk=(uk)(N) = (0.207)(1300-310sin20) = 247.15 N
sumFx= Fx-Fk =310cos20-247.15 = 44.15 N
F=ma=44.15
a=44.15/1300 =0.0340 m/s^2
Answer says a=0.331
Can someone point out what I did wrong? Thanks
Doesn't gravity exert a force in the y direction, contributing to Fy ?
The Fy you have is downward. Do you want that to be negative ?
im not sure if I quite follow. Yes, force of gravity (1300N) is exerted in the y-direction:
F1y= 310sin20
N=1300-310sin20
sumFy=N+F1y-1300N=0
I'm not sure what is wrong. Can someone help me out?
The applied force is downward:
Joe26 said:
a force of 310 N at an angle of 20.0° below the horizontal.
sorry that should be above the horizontal
Joe26 said:
F=ma=44.15
1300 N is the weight of the crate, not its mass.
so, how would i be able to find the acceleration?
Just like you tried to do, only first find the mass of the crate. How do weight and mass relate to each other?
Got it, thanks. W=mg...find m using weight and use f=ma to find acceleration.
