Finding charge so that the electric field is zero
1 reply · 3K views
trip727
Two tiny objects with equal charges of 65.0 µC are placed at two corners of a square with sides of 0.335 m, as shown. How far above and to the left of the corner of the square labeled A would you place a third small object with the same charge so that the electric field is zero at A?
above corner A= ?m
to the left of corner A= ?m
image http://www.webassign.net/grr/p16-27.gif
Coulomb's Law: F = (k * q1 * q2 ) / r^2
Electric Field: = k*q / r^2
.56332741
Force from just below A.
d = 0.335 m
k = 9*10^9
q1 = 65 *10^-6 C
E = kq1/d^2
E = 9*10^9*65*10^-6/(0.335)^2
E =5212752.26 N/q
Force from charge on the same diagronal as A
d = sqrt(0.335^2 + 0.335^2) A diagronal of a square = sqrt(side^2 + side^2)
d = 0.4737 m
E2 = k*q1/d
E2 = 9*10^9 * 65 * 10^-6/(0.4737)^2
E2 = 2607048.416 N/q
Summing the Fields.
Vertical
Total Vertical = 5212752.26 + 2607048.416 *Sin(45o)
the angle a diagonal makes with with vertical is 45o
Total Vertical = 5212752.26 N/q + 1843461.614 N/q
Total Vertical = 7056213.874 N/q
Total Horizontal = 2607048.416 * cos(45o)
Total Horizontal = 1843461.614 N/q
I used the following equation for the rest, but I am not getting the right answer, please if anyone can help me, this is due in an hour. Thank you so much I've been trying this for hours
d^2 = kq1/E
Welcome to PF, trip!
Just some tips - you will want to do this yourself. No need to work with the numbers for the charge or the distance until the very end. In fact, the charges all cancel out in the calcs.
Call the .335 m by the letter d. The diagonal distance is the square root of 2d².
Then the horizontal component of E at A due to the charge q on the right is
Ex = kq/(2d²). The vertical Ey is a very similar expression, just 3/2 times Ex, I think.
Next, let x,y be the location of the third charge from A.
For its Ex and Ey due to the 3rd charge (exactly equal to the ones already found) I got something like Ex = kqx/Z, where Z is (x² + y²) to the power 3/2 for that after expressing the cos A in terms of x and the hypotenuse. A similar expression for Ey. Now I have two equations in x and y to solve simultaneously. I solved one for Z, subbed into the other and immediately got x =3y. (Better check that!) Only a little more work to get the actual values for x and y as simple multiples of d. Much, much less work than you did!
