I Finding components in momentum representation
IanBerkman
Dear all,
I am trying to understand how they get they get the following components:
$$c_\textbf{p} = \langle \textbf{p} | \psi\rangle = \int \frac{d\textbf{r}}{\sqrt{V}}e^{-\frac{i}{\hbar}\textbf{p}\cdot\textbf{r}}\psi(\textbf{r})$$
Where ##|\textbf{p}\rangle## are the plane waves
|\textbf{p}\rangle = \frac{1}{\sqrt{V}}e^{-iEt/\hbar}e^{i\textbf{p}\cdot\textbf{r}/\hbar}$$
I understand the step
$$\langle \textbf{p} | \psi\rangle = \int d\textbf{r}\langle\textbf{p}|\textbf{r}\rangle\langle\textbf{r}|\psi\rangle = \int d\textbf{r} \langle\textbf{p}|\textbf{r}\rangle \psi(\textbf{r})$$
But not how
$$ \langle\textbf{p}|\textbf{r}\rangle = \frac{1}{\sqrt{V}}e^{-\frac{i}{\hbar}\textbf{p}\cdot\textbf{r}}$$
You should be much more careful in your notation. An abstract ket is not a wave function to begin with. Using the correct Dirac notation, which is utmost mnemonic, helps a lot in getting this things straight. If you have a normalized Hilbert-space vector, the wave function in position representation is given by
$$\psi(\vec{r})=\langle \vec{r}|\psi \rangle.$$
The generalized momentum eigenstates in a finite volume (most simply a cube with wave functions defined with periodic boundary conditions, because otherwise momentum doesn't make any sense as an observable) are given in position representation by (setting ##\hbar=1##)
$$\langle \vec{x}|\vec{p} \rangle =\frac{1}{\sqrt{V}} \exp(\mathrm{i} \vec{p} \cdot \vec{x}),$$
as can be shown by the fact that ##\hat{\vec{p}}## is the operator of spatial translations. With the boundary conditions the momenta are discretized as
$$\vec{p} \in \frac{2 \pi}{L} \mathbb{Z}^3, \quad L^3=V.$$
Now you have the completeness relations
$$\sum_{\vec{p}} |\vec{p} \rangle \langle \vec{p}|=\mathbb{1}, \quad \int_{Q} \mathrm{d}^3 \vec{x} |\vec{x} \rangle \langle \vec{x}|=\mathbb{1}.$$
Via these completeness relations you get indeed the correct transformation from the wave function in position representation to the wave function in momentum representation and vice versa as you've written in your posting #1. In this case it's nothing else than the usual Fourier-series theory for periodic functions. In the limit ##L \rightarrow \infty## momentum becomes continuous with the spectrum ##\vec{p} \in \mathbb{R}^3##, and the Fourier-series transformations go into Fourier-integral transformations. The orthonormalization conditions ##\langle \vec{p}|\vec{p}' \rangle=\delta_{\vec{p},\vec{p}'}## for the finite volume become ##\delta##-distributions in the infinite-volume limit ##\langle \vec{p}|\vec{p}' \rangle=\delta^{(3)}(\vec{p}-\vec{p}')##.
Likes IanBerkman
Thank you for the explanation, you have made it a lot more clear. The problem was indeed that I described ##|\textbf{p}\rangle## as a wave function instead of a momentum eigenstate.
What happens when the completeness relations are unequal to 1? Is it not possible then to find momentum eigenstates in coordinate representation?
Well, then your orthonormal system of (generalized) vectors is incomplete, and you must find the missing vectors to get a complete basis.
That makes sense, thank you.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
