Finding Constructive Interference
To experience constructive interference from two in-phase loudspeakers 53.2 m apart emitting sound at 459 Hz, the listener must sit at specific distances where the path lengths to each speaker differ by an integer multiple of the wavelength. The wavelength can be calculated using the speed of sound, which is approximately 343 m/s, resulting in a wavelength of about 0.75 m. Therefore, the listener can find additional positions by determining distances from the midpoint that are integer multiples of this wavelength. The discussion emphasizes the importance of understanding wave interference principles to identify these positions effectively. Ultimately, the goal is to locate the closest points to the midpoint where the sound is amplified due to constructive interference.
Patdon10
A college student is at a concert and really wants to hear the music, so she sits between two in-phase loudspeakers, which point toward each other and are 53.2 m apart. The speakers emit sound at a frequency of 459 Hz. At the midpoint between the speakers, there will be constructive interference, and the music will be at its loudest. At what distance closest to the midpoint could she also sit to experience the loudest sound?
My book is absolutely useless in this problem. It really gives no useful information in how to solve this problem. Can anyone point me in the right direction?
I learn through examples, and I'm absolutely willing to try. This problem is from my last homework assignment (meaning it won't help my grade), I'd just like to learn how to do it.
Constructive interference happens when the path lengths to the two sources differ by an integer multiple of a wavelength. That way, the crest from one wave reaches the listener at the same time as the crest from the other, and ditto for the trough. So, which other places between the two speakers have path lengths that differ by an integer multiple of 53.2 m?
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 20 ·
