Finding eigenvalue and normalized eigenstate of a hamiltonian
The discussion focuses on finding the eigenvalues and normalized eigenstates of a Hamiltonian modified by an additional potential term. The original Hamiltonian has two orthogonal energy eigenstates with the same eigenvalue, E_0. The new Hamiltonian, H, is represented as a matrix that combines the original Hamiltonian and the potential V, with specific matrix elements defined. Participants emphasize using linear algebra techniques to compute the eigenvalues and eigenvectors, noting the importance of ensuring that the eigenvalues remain real. The conversation concludes with a reminder about the conditions on the potential elements when determining the eigenvalues.
noblegas
The system described by the Hamiltonian H_0 has just two orthogonal energy eigenstates, |1> and |2> , with
<1|1>=1 , <1|2> =0 and <2|2>=1 . The two eignestates have the same eigenvalue , E_0:
H_0|i>=E_0|i>, for i=1 and 2.
Now suppose the Hamiltonian for the system is changed by the addition of the term V, given H=H_0+V.
The matrix elements of V are
<1|V|1> =0 , <1|V|2>=V_12, <2|V|2>=0.
a) Find the eigenvalues of the new Hamiltonian, H , in terms of the quanties above
b) Find the normalized eigenstates of H in terms of |1> , |2> and the other given expressions.
a) I don't know how to begin this problem but I guess I will start by plugging in the values for H_0 and V: H=H_0+V=<1|1>+<1|V|1>=1+0=1 for the first value of H_0 and the first value of V. don't you find the eigen value by writing out this expression: det(H-I*lambda)=0? I have kno w idea.
I think this problem is more easily seen as a matrix:
<br /> H=\left(\begin{array}{cc}E_0 &amp;0 \\ 0 &amp; E_0\end{array}\right)+\left(\begin{array}{cc}0&amp;V_{12} \\ V_{21} &amp; 0\end{array}\right)=\left(\begin{array}{cc}E_0&amp;V_{12} \\ V_{21} &amp; E_0\end{array}\right)<br />
You can then use linear algebra methods to calculate the eigenvalue \lambda and then the eigenvectors (eigenstates) from the new eigenvalues.
Should I write out a matrix for V_11 an V_22 as well, along with E_1 and E_2?
You've already shown that V_{11}=V_{22}=0, and I included this in the perturbed potential:
<br /> V=\left(\begin{array}{cc}V_{11}&amp;V_{ 12} \\ V_{21} &amp; V_{22}\end{array}\right)=\left(\begin{array}{cc}0&amp;V_{ 12} \\ V_{21} &amp; 0\end{array}\right)<br />
Likewise, you have already claimed that \langle1|H|1\rangle=\langle2|H|2\rangle=E_0 and I too added them in for H_0.
For part b, would I go about and normalized a matrix by multiplying V by its complex conjugate, i.e., VV*dr=1?
No, you need to find the eigenvectors (eigenstates) from your eigenvalues found using this Hamiltonian:
<br /> H=\left(\begin{array}{cc}E_0&amp;V_{ 12} \\ V_{21} &amp; E_0\end{array}\right)<br />
Small hint: You correctly wrote the equation necessary to find the eigenvalues in your first post. Once you find the eigenvalues, how do you find the associated eigenvectors?
You would do the hamiltonian-lambda*I and you would find the determinate of det(hamiltonian-lambda*I )=0 to find the values of lambda right? then I would normalized the hamiltonian?
Yes then no. You are correct in finding your eigenvalues (\lambda), but you are not asked to normalize the Hamiltonian, you are asked to find the normalized eigenstates (which are the same thing as eigenvectors). If you are unfamiliar with this process, then I would recommend checking out http://www.tmt.ugal.ro/crios/Support/ANPT/Curs/math/s3/s3eign/s3eign.html"
<br /> <br /> H=\left(\begin{array}{cc}E_0 &amp;0 \\ 0 &amp; E_0\end{array}\right)+\left(\begin{array}{cc}0&amp;V_{ 11} \\ V_{11} &amp; 0\end{array}\right)=\left(\begin{array}{cc}E_0&amp;V_{ 11} \\ V_{21} &amp; E_0\end{array}\right)<br /> would I write two other matrixes fo and <br /> <br /> H=\left(\begin{array}{cc}E_0 &amp;0 \\ 0 &amp; E_0\end{array}\right)+\left(\begin{array}{cc}0&amp;V_{ 22} \\ V_{22} &amp; 0\end{array}\right)=\left(\begin{array}{cc}E_0&amp;V_{ 22} \\ V_{21} &amp; E_0\end{array}\right)<br /> <br />
No...V_{11}=V_{22}=0. These have already been included, as I said in Post #4. You just need to find \lambda from
<br /> \det\left[\left(\begin{array}{cc}E_0&amp;V_{ 12} \\ V_{21} &amp; E_0\end{array}\right)-\left(\begin{array}{cc}\lambda&amp;0 \\ 0 &amp; \lambda\end{array}\right)\right]=0<br />
and then find the associated eigenvectors from this and then normalize them.
I would have two values for lambda right? and my eigenvectors would be: <br /> <br /> H=\left(\begin{array}{cc}E_0 &amp;0 \\ 0 &amp; E_0\end{array}\right)+\left(\begin{array}{cc}0&amp;V_{ 12} \\ V_{21} &amp; 0\end{array}\right)=\left(\begin{array}{cc}E_0&amp;V_{ 12} \\ V_{21} &amp; E_0\end{array}\right)<br /> <br />*[x,y]=lambda_1*[x,y], and <br /> <br /> H=\left(\begin{array}{cc}E_0 &amp;0 \\ 0 &amp; E_0\end{array}\right)+\left(\begin{array}{cc}0&amp;V_{ 12} \\ V_{21} &amp; 0\end{array}\right)=\left(\begin{array}{cc}E_0&amp;V_{ 12} \\ V_{21} &amp; E_0\end{array}\right)*[x,y]=lambda_2*[x,y] right
noblegas said:
I would have two values for lambda right? and my eigenvectors would be: <br /> <br /> H=\left(\begin{array}{cc}E_0 &amp;0 \\ 0 &amp; E_0\end{array}\right)+\left(\begin{array}{cc}0&amp;V_{ 12} \\ V_{21} &amp; 0\end{array}\right)=\left(\begin{array}{cc}E_0&amp;V_{ 12} \\ V_{21} &amp; E_0\end{array}\right)<br /> <br />*[x,y]=lambda_1*[x,y], and <br /> <br /> H=\left(\begin{array}{cc}E_0 &amp;0 \\ 0 &amp; E_0\end{array}\right)+\left(\begin{array}{cc}0&amp;V_{ 12} \\ V_{21} &amp; 0\end{array}\right)=\left(\begin{array}{cc}E_0&amp;V_{ 12} \\ V_{21} &amp; E_0\end{array}\right)<br /> <br /> <br />*[x,y]=lambda_2*[x,y] right
This is correct. I will note that there will be a condition involved on V_{12} and V_{21} in finding your eigenvalues. When finding \lambda, remember that your eigenvalues must be real.
  • · Replies 0 ·
