Finding eigenvectors of similar matrices
Alupsaiu
If v is in Rn and is an eigenvector of matrix A, and P is an invertible matrix, how would you go about finding an eigenvector w of PAP-1?
I'm thinking you have to use a fact about similarity?
Just use Pv. Then PAP-1(Pv) = PAv = P \lambda v = \lambda Pv.
Man I hate how painfully simple problems like these are when you see them done haha...thanks a bunch
No problem. To give some intuition for this, you should think of an invertible matrix P as giving a "symmetry" of Rn. Then conjugation by P is the corresponding symmetry of the space of nxn matrices. That's really why people care about similar matrices. If two matrices are similar, then there is some "symmetry" that can transform one matrix into the other.
Another way to think about it: two matrices are similar if and only if they represent the same linear operator, written in different bases (P is the "change of basis" matrix). They necessarily have the same eigenvalues since changing bases would only change vectors, not scalars.
Thread 'Determine whether ##125## is a unit in ##\mathbb{Z_471}##'
This is the question, I understand the concept, in ##\mathbb{Z_n}## an element is a is a unit if and only if gcd( a,n) =1. My understanding of backwards substitution, ... i have using Euclidean algorithm, ##471 = 3⋅121 + 108## ##121 = 1⋅108 + 13## ##108 =8⋅13+4## ##13=3⋅4+1## ##4=4⋅1+0## using back-substitution, ##1=13-3⋅4## ##=(121-1⋅108)-3(108-8⋅13)## ... ##= 121-(471-3⋅121)-3⋅471+9⋅121+24⋅121-24(471-3⋅121## ##=121-471+3⋅121-3⋅471+9⋅121+24⋅121-24⋅471+72⋅121##...
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
