Equation of a Circle Passing Through Given Points
  • Thread starter Thread starter furtivefelon
    Circle
To find the equation of a circle that passes through the y-axis and x-axis and the point (8, -1), it is essential to understand that the circle is tangent to these axes. The equation should be in the form (x-h)² + (y-k)² = r², where (h, k) is the center and r is the radius. The radius can be determined as either 8.5 or 0.5, depending on the center's position. The discussion emphasizes using geometric principles and the Pythagorean theorem to derive the solution. Understanding the tangential relationship to the axes is crucial for solving the problem correctly.
furtivefelon
hi, this isn't really a physics problem, more of a math problem, however, i can't find a math forum.. so i thought i'd put it here :D
your given that a circle passes through y-axis adn x-axis, also the circle passes through the points (8, -1).. find the equation of the circle, reminded that the equation should be in the following form: (x-h)^2+(y-k)^2=r^2
i have no idea how i should approach this problem, thanks a lot for your help :P
What are the other points?
that's teh whole question.. that's suppose to be the hardest problem on the sheet, and since there are no any other point, i can't figure it out :|
What do you mean my passes through "y" & "x" axis...?Shouldn't it be the other way around...?:wink: Actually,i think they mean that the circle is tangent to those lines...
I found the radius to be either 8.5,or 0.5.You decide which value is correct...
Daniel.
mmm.. yes, it indeed is tangent to the x/y axis.. can you tell me how you got it? i care more about the process than the result :D thank you very much!
Draw a circle & use geometry in a pythagoreic triangle...
Daniel.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
